How do I adjust my 74' RoadRunner horn? #75416
06/18/08 11:34 AM
06/18/08 11:34 AM
OHIO,USA
BMOTOXSTAR Offline OP
OHIO,USA
OK,
There are 2 knobs on my RR horn (74') a small one and a big thing in the middle. Which do I adjust to make it go beep beep?
Do I use a special tool or a socket?
Thanks Mopar buddies
Re: How do I adjust my 74' RoadRunner horn? [Re: BMOTOXSTAR] #75417
06/18/08 12:15 PM
06/18/08 12:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Do you want to change the tone? Then it will be the little oddball screw. To make it go beep beep you honk the horn twice quickly.
Re: How do I adjust my 74' RoadRunner horn? [Re: BMOTOXSTAR] #75418
06/18/08 12:15 PM
06/18/08 12:15 PM
Connecticut
LL340Rag Offline
LL340Rag  Offline
Connecticut
If they are original there is a small hole that uses an allen wrench to adjust them. I don't know on the repro's.
Re: How do I adjust my 74' RoadRunner horn? [Re: LL340Rag] #75419
06/18/08 07:32 PM
06/18/08 07:32 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The rr horn I have just has a little odd looking screw protruding out of it. Turn it just a little and it makes a change to the horn sound.
Re: How do I adjust my 74' RoadRunner horn? [Re: DaytonaTurbo] #75420
06/19/08 08:18 AM
06/19/08 08:18 AM
OHIO,USA
OHIO,USA
Thanks everyone,
I want the pitch to be different and sound like the cartoon.
