Re: How Difficult to Remove E-Body Rallye Gauge Cluster?
[Re: stan1970]
#75230
06/17/08 10:28 PM
06/17/08 10:28 PM
Posts: 6,252 Zzyzx Road
beepbeep
moparts member
moparts member
Zzyzx Road
Make sure the battery is disconnected.
Amazing how an unchallenged lie can become the absolute truth.
[Re: stan1970]
#75231
06/17/08 10:57 PM
06/17/08 10:57 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
On the Steering Column lowering - I noticed some older posts that said this is just the loosening of those two bolts under the column -- and another that said if you lower the Column it will have to be re-adjusted at the firewall??
Is it really as simple as just the two bolts or will I have to do more work on the column to get it back properly?
Thank You. --Stan
Just the two nuts that hold the U shaped braket. You do not have to loosen it at the firewall.
[Re: BDW]
#75235
06/18/08 09:10 PM
06/18/08 09:10 PM
70Fish
I've done this before too. One other tip is that the reset knobs for the clock/trip meter are held on by tiny screws on the inside of the shaft.
'70 Barracuda
'94 Harley Davidson FXDWG
Pit Bull named IKE
[Re: 70Fish]
#75236
06/18/08 09:29 PM
06/18/08 09:29 PM
Posts: 3,076 Renton, Wa.
Classof70Chally
super gas
super gas
Renton, Wa.
The best thing to use for those 'really tiny' screws is one of those cheapo eye glasses repair kits that come with a 'really tiny' screwdriver! Then, put a small piece of tape over the end of the knob, cause if you lose that 'really tiny' screw then, yep you guessed it, you'll be s-----d !
