window to metal bracket bonding ??? 71 road runner #750906
07/17/10 11:09 PM
07/17/10 11:09 PM
Missouri
71hoserunner Offline OP
Missouri
The quarter glass on my 71 Runner has a etched in bird so they need to be replaced. I have a nice set of glass from a 71 without roll down rear windows but the glass does not have the bracket bonded onto the glass like the roll down windows do. I believe the glass is the same, but how do I remove the bracket from the bad glass and bond the other to it?
Any help would be appreciated.
Thanks,
Keith
keithfoy@att.net
314-540-3782
71 Challenger Conv Restomod
2020 Charger SRT Hellcat Widebody Daytona 50Th Anniversary Edition #444
07 Ram 2500 4WD Diesel
Re: window to metal bracket bonding ??? 71 road runner [Re: 71hoserunner] #750907
07/18/10 06:59 AM
07/18/10 06:59 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I had the same situation on my truck. I needed the metal track taken off one window and put it on another. I took it to a glass shop. They charged around $10.
Re: window to metal bracket bonding ??? 71 road runner [Re: TooMany62s] #750908
07/18/10 08:32 AM
07/18/10 08:32 AM
IN
ahy Offline
ahy  Offline
IN
The glass shop sounds like a good idea.
I had to re-bond a steel channel to glass once. I used some glass bonding adhesive from the hardware store. It worked well after I tightened the channel for good mechanical grip to the glass.
A good coating of paint stripper on the old channels covered with plastic wrap would probably soften the old adhesive. Let it work for several hours.
