http://www.themotorbookstore.com/differentials.html--> I'm looking in my Amazon library for specifics....
Quote: "This book covers everything you need to know about selecting the most desirable gear ratio, rebuilding differentials and other driveline components, and most importantly, matching the correct driveline components to engine power output.
Learn how to set up a limited-slip differential, install high-performance axle shafts, swap out differential gears, and select the best available products for the driveline.
This book covers the Chevy 12-bolt, Ford 8.8-inch, Dana units, and many other popular high-performance axles and rear ends. In addition, it explains rear differential basics, rear differential housings, rebuilding open rear differentials, limited-slip differentials, and factory differentials. Ring and pinion gears, axle housings, axle shafts, driveshafts, and U-joints are also covered."
