Re: Is 210-220 too hot for 440 Big Block
[Re: moparrulzzz]
#749238
07/16/10 09:39 PM
07/16/10 09:39 PM
Posts: 137 Kenosha, WI wi/il border
BobN
Sorry -worked late here is info stock Iron 346 heads. had 3angle valve job Mild 440,.040 over, RPM intake,Comp XE268 cam, KB Hyper pistons . Mancini alumin water pump housing, Mopar hemi water pump,stock crank, 71 Mopar 3core 26"radiator, stock shroud,Mopar clutch fan. 180 thermostat, dynod at just about 400 HP & 500 torque.
aftermarket cheap temp gauge could be off. that is what I have been thinking. Since radiator never pukes out. I dont really want to go with aluminum rad or electric fans if I dont have too.
does drop to 199 -200 when moving but starts creeping when in traffic. i was thinking of just letting it go and see if it over heats or not\I also take off out of traffic before is gets over 210 or higher.
what do you think?
[Re: 68LAR]
#749241
07/19/10 04:03 PM
07/19/10 04:03 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
Not to start any arguments or anything, but how, or what determines "efficient operating temp."? I've been using a 160* stat for over 40 years, with no adverse effects on the engine or oil. Why should I change if what I have works for me?
I have to agree with the 160 philosophy... A stat does not regulate operating temperatures.. it only regulates when the water starts to circulate..
I run a 160 stat as I want my engine to run as cool as possible when racing.. but when driving on the street, the temp gauge will always sit at 180-ish..
[Re: Jeepmon]
#749242
07/19/10 05:19 PM
07/19/10 05:19 PM
Posts: 1,226 Cookeville
Chilort
Will Work For Mopars
Cookeville
I'm running a lot too warm on these hot summer days in Georgia myself. Luckily I've got an old school mechanic on speed dial (my dad). I've been throwing parts at my problem with little success. I've tried different t-stats, water pumps, fan clutches, different fans, and external trans cooler, adding a shroud, etc. My dad pulled a few tricks out of his hat the other night that I need to look at still. I don't have any kind of rubber or metal flap/guard over the top of the front of the radiator. I don't know if this makes a difference at higher speeds but at lower speeds it could be allowing hot air to recirculate from the back side of the radiator to the front (though maybe it could be a problem at speed too). He also didn't make his view of the use of infrared thermometers in automotive cooling systems clear until after I bought one. In his view, unless you have actual probes in the outlet and inlet to the engine you really don't know squat. I think you know a little more than squat but he's a black/white kind of guy. If a cooling system is working properly, with a 180* t-stat the engine outlet temp should never be above 180*, simple as that. You start going cooler with the t-stats and then you need more heat transfer capabilities.
[Re: Jeepmon]
#749243
07/19/10 05:35 PM
07/19/10 05:35 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Sorry but you might want to rethink what you typed there. A thermostat DOES regulate the coolant temp BY letting the water circulate at a set temperature.
I agree with the 160 degree stats aswell. I rather see 160 on the gauge then 190-200. Whenever the tempgauge goes north of 190 on hot days, I'm getting slightly worried if it might go any higher.
[Re: BigBlockMopar]
#749245
07/24/10 11:50 AM
07/24/10 11:50 AM
Jeepmon
Sunnyvale, CA
The key word there is "operating" temperature.. If your normal operating temperature is 185.. 195.. 205.. or whatever.. Once you reach that temperature, the stat will not make the motor cooler.. with the exception of being a flow restricter to help slow down the rate of water passing thru the radiator..
[Re: Todd]
#749247
07/24/10 02:59 PM
07/24/10 02:59 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I added a bottle of water wetter and dropped the temp 10*. JMO.
that stuff works good. IO don't even use anti-freeze anymore.
[Re: BigBlockMopar]
#749249
07/24/10 11:57 PM
07/24/10 11:57 PM
Posts: 10,198 Someplace you aren't
SomeCarGuy
I used to think the margin for error was worth it but I now like the 190 stat. If your system is set up correctly, it will not go over 200.
It was 100 here today and very high humidity and my car ever went over 200, at idle, around town low speed, or on the interstate hogging the hammer lane.
i don't even have a shroud of any kind either.
The oil now stays much cleaner, I'm certain that the engine sees less wear.
The cool underhood temps actually caused a lean condition for my carb. It is an AVS so the 3 step rods are hard to come by, 20 bucks a set and it is really just a shot in the dark on getting things right w/o a wide band. So the hotter stat brought things in line.
