higher altenator output swap
#74792
06/16/08 11:31 PM
06/16/08 11:31 PM
i have a 1928 dodge senior six street rod which is all mopar under the sheetmetal, 318,904 83/4 rear. my problem is added a/c unit from southern air which is supposedly pulling35amps all by itself. current alt. is not powerful enough. puts out 14.2 volts ok, but only63 amps.with lights and a/c and am/fm radio on car will cut out just too much of aload. couple of things i have been told so far is thatamp meter from donor dodge ,69-70 charger will only handle approx.35 amps thru it before frying it. this info came from several good streetrod parts suppliers and i dont see any reason to doubt them. a couple of suggestions for curing said problem so i can run 100 amp alt. have been swap gauge for 1 marked 60-0-60 gauge currently reads 40-0-40 when and what where these used in? other possible solution was to run 2 4awg rated wires from b post on alt. directly to battery ,giving electrons easier path to follow. suppoedly gauge will flicker as it charges or discharges, but will keep from frying gauge. by the way am using cluster that came fom 69-79 charger w/ 318 and auto w/a/c... doner car only had 53 amp. alt.also noted talk about hooking up 2 field alts. i only have one field connection plugged in was told by alt. repair shop to use either one. should i hook up second one and if so why? sorry if this is too long a note, will try to keep it shorter next time tahanks for any help anyone can provide in this matter.
Re: higher altenator output swap
[Re: DaytonaTurbo]
#74794
06/16/08 11:54 PM
06/16/08 11:54 PM
thanks for such fast response, a/c system has 2 fan systems 1 inside car, and 1 outside under remote condensor ,plus a/c clutch. was given this amp. number by manufacter of a/c system. custom built for this application. thanks
#74795
06/16/08 11:55 PM
06/16/08 11:55 PM
Posts: 7,664 IN
ahy
IN
Running a heavy wire from the alternator output post to the battery or starter relay of there is one will bypass the ammeter and support running a 100 A alternator. One 6 guage wire should be more than enough. Its recommended to splice several inches of fusible link in the 6 guage wire to protect the system from serious shorts. 10 guage fusible link should be about right and is available at auto electrical stores. The ammeter wouldn't work with this change. An accessory voltmeter would be a good replacement. Another and potentially bigger issue is why the car "cuts out" with high electrical load from the AC. Even with a small alternator it should run OK for quite a while on battery power. OE Mopar's were orignally designed this way; they would discharge at a stoplight and "catch up" running down the road. It sounds like the AC may be on a weak or overloaded connection on the original donar car's wiring. Original AC would draw +/-15 amps so if you're pulling 35 that's too much for the original wiring. I'd check all connections and consider running a dedicated power supply for the AC with 10 guage minimum wire from the starter relay or battery with an appropriate fuse. 35A sounds like a lot for AC but I guess the manufacturer knows The 2 field upgrade will help and may be necessary depending on what alternator you choose. Consult a wiring diagram for a 70 or later Mopar as a guide. (I don't have access to one now). Good luck.
