Did TBI 318s come with eccentrics? #74789
06/16/08 11:18 PM
06/16/08 11:18 PM
Sarcoxie, MO, USA
MoPar Jamie Offline OP
Sarcoxie, MO, USA
Hey all,
I'm converting an '88 W-150 over to a carb due to wiring issues. Got the tank and lines switched from an '84 D-150 and the wiring from the '86 donor works well with the '88 dash harness.
Anyway did 318-TBI motors come with fuel pump eccentrics on the front of the cam? I'm thinking they probably did but I want to be sure. I put a std. pump on it and it didnt pump. I just want to be sure there is one of those little guys in there. If not I've got a parts 318 with one and a new timing chain!
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: Did TBI 318s come with eccentrics? [Re: MoPar Jamie] #74790
06/16/08 11:23 PM
06/16/08 11:23 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You have to look to be sure. Some will accept the cam and washer if not there.
Re: Did TBI 318s come with eccentrics? [Re: NITROUSN] #74791
06/17/08 02:09 AM
06/17/08 02:09 AM
& if not hughes has the bolt on nub to add an eccentric & use an earlier timing cover/fuel pump for less that $20
