Firm Feel fast ratio pitman arm and idler arm #74728
06/16/08 10:19 PM
06/16/08 10:19 PM
templeton,ma
coro500net Offline OP
templeton,ma
Has anybody installed these arms from firm feel?
Just wondering if they are worth the money over
the stock set up.
Re: Firm Feel fast ratio pitman arm and idler arm [Re: coro500net] #74729
06/16/08 10:21 PM
06/16/08 10:21 PM
Kirkland, Washington
Pacnorthcuda Offline
I have the fast ratio pitman on a 70 cuda. It does make a big difference, makes a fast system out of a slow one. Still overassisted though.
Re: Firm Feel fast ratio pitman arm and idler arm [Re: Pacnorthcuda] #74730
06/16/08 10:30 PM
06/16/08 10:30 PM
Redmond, Wa,
8
8WHEELER Offline
8WHEELER  Offline
Redmond, Wa,
For me it was worth it, I used the stage two box as well. Even better beeing able to pick it up in person.
Dan
Re: Firm Feel fast ratio pitman arm and idler arm [Re: coro500net] #74731
06/16/08 10:38 PM
06/16/08 10:38 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
If you have headers you should double check. There is no romm for the pitman on my car.
Re: Firm Feel fast ratio pitman arm and idler arm [Re: coro500net] #74732
06/16/08 11:01 PM
06/16/08 11:01 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I have the fast ratio arms with the stage 3 steering box. It made a big difference compared to the oem set up. You can use the c-body idler?.... to save a few dollars.
On big blocks most of the 1 3/4 headers will fit since they all route the tubes pretty much the same. TTI 2" headers are the only larger tube header that I found that clears.
Re: Firm Feel fast ratio pitman arm and idler arm [Re: RTSE4ME] #74733
06/16/08 11:20 PM
06/16/08 11:20 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
I did the stage 2 box with both arms... WORLD of difference.
