94 sundance 2.2 won't start but cranks help... #74721
06/16/08 09:52 PM
06/16/08 09:52 PM
NEW JERSEY
AARCONV Offline OP
AARCONV  Offline OP
NEW JERSEY
friends 1994 sundance 2.2 4cylinder, cranks won't start...no spark at the cap....where to start?...any known problems?..didn't these have that hall sensor in the distributer?
Re: 94 sundance 2.2 won't start but cranks help... [Re: AARCONV] #74722
06/16/08 10:00 PM
06/16/08 10:00 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Well, for starters, it does have a conventional coil. Is there spark there? Also, running the codes is pretty easy... Have the cap/rotor been checked?
2 Demons...no, not my kids!
Re: 94 sundance 2.2 won't start but cranks help... [Re: 4speeds4me] #74723
06/16/08 10:10 PM
06/16/08 10:10 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
timing belt.does the dist turn?? bad cap /rotor wires??
dist has a hall effect sensor.can jump two terminals and create a spark.
There is a wire in the harness near the asd relay.blue or a green wire that corrodes and breaks inside the main taped up harness.1 wire branchs off into like 4 or 5 wires.breaks there.check for +Power at the coil.No key on power/asd relay power.open up the harness along the driver side inner fender area.
Re: 94 sundance 2.2 won't start but cranks help... [Re: moretoys] #74724
06/16/08 10:13 PM
06/16/08 10:13 PM
NEW JERSEY
AARCONV Offline OP
AARCONV  Offline OP
NEW JERSEY
dist turns,no spark when holding the coil wire to ground...
Re: 94 sundance 2.2 won't start but cranks help... [Re: AARCONV] #74725
06/16/08 11:55 PM
06/16/08 11:55 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Check codes (key on-off-on-off-on rapidly WITHOUT trying to start it). Count flashes of the check engine light. There will be a longer pause between digits and all codes are two-digit. You will probably see a "12" first and a "55" at the end. "12" is loss of battery within a certain number of starts (50 or something) and "55" is end of codes. Lots of palces on the net to find the codes, but the best I've found is http://minimopar.knizefamily.net/.
Re: 94 sundance 2.2 won't start but cranks help... [Re: Jim_Lusk] #74726
06/17/08 09:42 AM
06/17/08 09:42 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
wiggle the wiring to the pick-up plate while having someone crank it.
Re: 94 sundance 2.2 won't start but cranks help... [Re: J_BODY] #74727
06/18/08 08:23 PM
06/18/08 08:23 PM
NEW JERSEY
AARCONV Offline OP
AARCONV  Offline OP
NEW JERSEY
was code 11, pick up coil doa..
thanks
