Drilling throttle plates? #74660
06/16/08 08:46 PM
06/16/08 08:46 PM
Anonymous OP
Anonymous OP
When i try to adjust my carb with the idle mixture screws i dont see much change in idle or vac. readings The carbs are a 6 pac set up do you guys think I should drill the throttle plates? The car seems to run fine and idle about 1100 just doesn't respond to the mixture screws. What should I do ? THANKS for any help EDDIE B
Re: Drilling throttle plates? #74661
06/16/08 09:30 PM
06/16/08 09:30 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
If the mixture screws don't affect the engines idle performance then you are usually into the transfer slots with the blades. But, this should also cause a rich condition. If your engine is idling satisfactorily why screw with it? If you are into the transfer slots then yes drilling the blades should alleviate that situation. Warning. Be prepared to have to do some tuning to get it all correct. -Bob
Re: Drilling throttle plates? [Re: BobR] #74662
06/17/08 05:52 PM
06/17/08 05:52 PM
Anonymous OP
Anonymous OP
Re: Drilling throttle plates? [Re: BobR] #74663
06/17/08 05:57 PM
06/17/08 05:57 PM
Marine Corps Base Hawaii
DemonKyle Offline
USMC LCPL
DemonKyle  Offline
USMC LCPL
Is the gauge hooked up to the metering plate or the main body?
Re: Drilling throttle plates? #74664
06/17/08 06:30 PM
06/17/08 06:30 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
NO , you don't need to drill the throttle plates on street driven cars.
NO - drill - plate!
Re: Drilling throttle plates? #74665
06/17/08 06:41 PM
06/17/08 06:41 PM
Anonymous OP
Anonymous OP
drop the idle to 800-900rpm. then see. 1100 is to high.
Re: Drilling throttle plates? [Re: mark7171] #74666
06/17/08 06:47 PM
06/17/08 06:47 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
P.S. How many tuning threads you going to open?
Never mind!
Re: Drilling throttle plates? [Re: RobX4406] #74667
06/17/08 08:33 PM
06/17/08 08:33 PM
Anonymous OP
Anonymous OP
rob,what do you mean how many tuning threads am i going to open? EDDIE B
Re: Drilling throttle plates? #74668
06/17/08 08:38 PM
06/17/08 08:38 PM
Anonymous OP
Anonymous OP
i'm assuming the meglomaniac is wondering how many "how to tune" threads your gonna post.
Re: Drilling throttle plates? #74669
06/17/08 08:48 PM
06/17/08 08:48 PM
Anonymous OP
Anonymous OP
Well I thought that was what this board was all about that guy can kiss my azz.
Re: Drilling throttle plates? #74670
06/17/08 08:55 PM
06/17/08 08:55 PM
RobX4406 Offline
RobX4406  Offline
You have a few open and keep asking the same question... it's a waste of time and best of luck to you if you don't want to keep it in one thread.
Greg, you feeling all right??? megalomaniac??? That's rich You still want those rear rails???
Re: Drilling throttle plates? [Re: RobX4406] #74671
06/17/08 09:11 PM
06/17/08 09:11 PM
Anonymous OP
Anonymous OP
I've never asked about drilling throttle plates,I guess everyone isn't as blessed as you and have all the answers.
Re: Drilling throttle plates? #74672
06/17/08 09:17 PM
06/17/08 09:17 PM
RobX4406 Offline
RobX4406  Offline
And the title of this thread is what exactly????
If you don't have any other threads or asked a similar question elsewhere, I apologize. Seems I've seen you ask this in another thread.
You likely have an issue in another system on the car, not in the fuel system. You're trying to band-aid it with the carb. IMO, your combo should idle in the 800-900 range with 10-11" vacuum.
And the "Dan" crack has to do with something else.
Re: Drilling throttle plates? [Re: mark7171] #74673
06/17/08 10:47 PM
06/17/08 10:47 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
NO - drill - plate!
Drill as a last resort and you are not there yet.
I was on the border of drilling plates and I was able to tune it out. Much happier now and no drilling.
Re: Drilling throttle plates? [Re: RobX4406] #74674
06/17/08 10:50 PM
06/17/08 10:50 PM
Anonymous OP
Anonymous OP
Rob.. i'm KIDDING buddy your one of the most stand up kinda guys i know.
