need a 360 flywheel, where best place to buy? #74608
06/16/08 07:11 PM
06/16/08 07:11 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
need a flywheel for my 72 360. for a car.so it needs to be the 130 tooth one.
where is the best place to get a good deal on one?
thanks
Re: need a 360 flywheel, where best place to buy? [Re: dirt] #74609
06/16/08 07:28 PM
06/16/08 07:28 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Re: need a 360 flywheel, where best place to buy? [Re: In_The_Pink] #74610
06/16/08 11:59 PM
06/16/08 11:59 PM
dogdays Offline
dogdays  Offline
$270??? is that a good deal? non SFI to boot. Check the aftermarket.
I couldn't find one at NAPA or Autozone or Checker/Advance, so the low cost cast replacements seem to be missing.
That's enough to make you go automatic!
R.
Re: need a 360 flywheel, where best place to buy? [Re: dogdays] #74611
06/17/08 12:30 AM
06/17/08 12:30 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Here's the diagram to take a neutral unit and un-balance it for 360 use...
2 Demons...no, not my kids!
Re: need a 360 flywheel, where best place to buy? [Re: 4speeds4me] #74612
06/17/08 07:09 AM
06/17/08 07:09 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I sent you a PM...
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: need a 360 flywheel, where best place to buy? [Re: 4speeds4me] #74613
06/17/08 07:38 AM
06/17/08 07:38 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
will the diagram to drill the flywheel work on a 130 tooth wheel from a 340? looks to me like it will. . I have a bench drill press and probably the right drill bit too.looks easy to do. anyone ever tried it?
thanks!
Re: need a 360 flywheel, where best place to buy? [Re: dirt] #74614
06/17/08 08:21 AM
06/17/08 08:21 AM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
Wow, you've got a 1-13/64" drill bit?
Of course the magic number is X.XX in-oz of imbalance, not necessarily just 3 holes of a certain size. Also, steel flywheels may not use the same size holes due to differences in the mass of the materials. I think the diagram above is only truly valid for cast flywheels, but it might be "close enough" for steel flhwheels too.
Clair
Re: need a 360 flywheel, where best place to buy? [Re: dirt] #74615
06/17/08 09:42 AM
06/17/08 09:42 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I have a jig used to drill those balance holes. If you have a 318 flywheel, I can convert it.
Re: need a 360 flywheel, where best place to buy? [Re: DoctorDiff] #74616
06/17/08 11:16 AM
06/17/08 11:16 AM
that drill bit size is very expensive if you don't have it already & you will need to do some trigonometry along with the MP diagram.
Re: need a 360 flywheel, where best place to buy? [Re: RapidRobert] #74617
06/17/08 12:34 PM
06/17/08 12:34 PM
dogdays Offline
dogdays  Offline
Probably be cheaper to get a 318 wheel, ship it to DrDiff, have him do the drilling and ship it back!
R.
Re: need a 360 flywheel, where best place to buy? [Re: dogdays] #74618
06/17/08 02:26 PM
06/17/08 02:26 PM
Probably be cheaper to get a 318 wheel, ship it to DrDiff, have him do the drilling and ship it back! R.
I'm with Dog.
