Fan Clutch, Thermal or not, HD or what to buy? #74566
06/16/08 05:26 PM
06/16/08 05:26 PM
SC
V194 Offline OP
V194  Offline OP
SC
Looking for a new fan clutch on my 70 Cuda 340 with AC. The old unit may be failing so rather than risking it I decided to replace it.
I don't have an over-heating problem so I don't know what to go with. The parts counter guy is as usual no help.
So Should I seek a HD unit? Should I get a thermal or not thermal unit?
Any suggestions?
Re: Fan Clutch, Thermal or not, HD or what to buy? [Re: V194] #74567
06/16/08 05:39 PM
06/16/08 05:39 PM
scratchnfotraction Offline
IMO a thermo would be best for street
when mine is idleing for a while you can hear the fan clutch go in and out with the t stat cycling
for cooling I uped to a 7 blade fan off a amc hornet and put it on a stock thermo fan clutch
I did not have a cooling prob and the temp went down 10*,so I bumped the t stat back up from 160* to a 180*
Re: Fan Clutch, Thermal or not, HD or what to buy? [Re: scratchnfotraction] #74568
06/16/08 08:16 PM
06/16/08 08:16 PM
for cooling I uped to a 7 blade fan and put it on a stock thermo fan clutch
Re: Fan Clutch, Thermal or not, HD or what to buy? [Re: V194] #74569
06/17/08 08:40 AM
06/17/08 08:40 AM
Virginia
rm23j8g Offline
rm23j8g  Offline
Virginia
The current fan clutch available from Chrysler is a thermal unit, and, when installed, looks almost exactly like an original non-thermal unit from the back. In the case of your car, which probably had a thermal unit originally, this should be perfect.
Not a cheap as one you can get from Autozone and the like, but they really look great.
I recently bought one for my AAR, to use until I eventually get the original one rebuilt. It looks so good, I may just leave it.
Re: Fan Clutch, Thermal or not, HD or what to buy? [Re: RapidRobert] #74570
06/17/08 08:54 AM
06/17/08 08:54 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Yup, works really well and looks factory
Re: Fan Clutch, Thermal or not, HD or what to buy? [Re: rm23j8g] #74571
06/17/08 10:56 AM
06/17/08 10:56 AM
Upper Midwest
Black_Sheep Offline
Black_Sheep  Offline
Upper Midwest
IIRC the MP fan package uses a viscous clutch. Either type will work but I figured having the fan clutch slip during hard acceleration would be easier on the belt and probably free up a little power. There's been an aftermarket viscous fan clutch on the GTX for 6 years without any cooling issues...
'69 Plymouth GTX
See you on the street...
Re: Fan Clutch, Thermal or not, HD or what to buy? [Re: V194] #74572
06/17/08 04:40 PM
06/17/08 04:40 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Which clutch are you running now, thermal or non thermal? If you like what it's doing now, I'd personally just get a direct replacement.
