master cylinder push rod #74529
06/16/08 02:25 PM
06/16/08 02:25 PM
Iowa
P
plumcrazyb Offline OP
P
Iowa
70B body, 11" manual drums. How do you get the brake pushrod out? The replacement appears to not have one from the pictures I've seen.
Re: master cylinder push rod [Re: plumcrazyb] #74530
06/16/08 02:49 PM
06/16/08 02:49 PM
Andrewh Offline
Andrewh  Offline
Just bolt the rod back to the pedal and pull. or feets uses a rolling jack to do it, but don't remember.
Careful if you put it in to do it to make sure fluid doesn't spew.
Re: master cylinder push rod [Re: Andrewh] #74531
06/16/08 03:51 PM
06/16/08 03:51 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i remove the master cylinder with rod attached and use an xacto knife with a pointed blade to cut out the rubber holding the rod in. doesn't tear up any parts, other than the rubber piece.
Re: master cylinder push rod [Re: lewtot184] #74532
06/16/08 07:34 PM
06/16/08 07:34 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
remove it with the rod attached, put the rod in a bench vise and use a big screwdriver to pop them apart,OR
put the cylinder in the vise and put a long rod, screwdriver, etc thru the hole and give it a yank..Some lube like PB blaster will help.
Re: master cylinder push rod [Re: plumcrazyb] #74533
06/16/08 07:55 PM
06/16/08 07:55 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
If you have a floor jack with a removable saddle, stick the pushrod down through the saddle hole and put a long screwdriver through the hole, perpendicular to the jack.
A couple of easy pumps on the jack handle and the pushrod will pop right out.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
