68 b body door weatherstripping removal #74325
06/16/08 12:53 AM
06/16/08 12:53 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
What is the best way to remove the old weather seal so it can be reused?
Re: 68 b body door weatherstripping removal [Re: sthemi] #74326
06/16/08 12:57 AM
06/16/08 12:57 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If your refering to the one aroud the perimeter of the door I typically break the white plastic clips then just replace the clips...Though they use to sell a pkg for $2.00 & the last time I needed a set they were $15.00
Re: 68 b body door weatherstripping removal [Re: 1_WILD_RT] #74327
06/16/08 07:38 PM
06/16/08 07:38 PM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks, what works best as far as breaking them clips and not wrecking the rubber?
Re: 68 b body door weatherstripping removal [Re: sthemi] #74328
06/16/08 08:53 PM
06/16/08 08:53 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I use a wide blade screwdriver from the side, line it up & a light sideways tap with the palm of your hand will break them off cleanly, then needle nose pliers to remove the part stuck in the weatherstrip....Get the new clips first & you'll see just how they install making removal easier...
Re: 68 b body door weatherstripping removal [Re: 1_WILD_RT] #74329
06/17/08 01:07 AM
06/17/08 01:07 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks for the help,
I used my gasket scraper between the rubber and door and gave each pin a light rap and off they came..
