Page 3 of 5 1 2 3 4 5
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: Valiant_Showoff] #742882
07/08/10 04:29 PM
07/08/10 04:29 PM
Lehigh Acres, Florida
rickstershemi Offline OP
Thanks Mark, do you have the Schumacher Motor Mounts also...?????
Dougs makes a nice header....happy to see they fit well....I wonder how they fit with a 4-speed z-bar....?????
What oil pan are you running...????
Rickster
This is going to sound crazy, but the motor mounts are home made. Just took the solid mounts that were on the engine when we got it off the wrecking pile and modified them to fit the cross member. The procedure went something like this:
Drank a couple beers. Bolted the mounts to the engine, lowered the engine into the bay, bolted up the transmission, and then set the engine where it "looked right". Drank another beer (or 2). Tack welded the mounts in place. Removed engine and tranny and built mounting ears to weld to the K-member for the mounts to hook to. Drank another beer and re-installed everything.
The oil pan is also home made. It's just the stock pan with the sump extended a couple inches for more capacity. Oil pick-up tube was extended to match.
It's nice having a mad-scientist/mechanic/machinist/paint & body man for a brother! Thanks 6bblFLASH.
That would have taken me at least an 18 pack to accomplish, but the again when I think about it, I could have bought 5 or 6 cases for what mine cost....
I may do the same with the oil pan, hoping to pick up a nice mig welding pkg this weekend I found on craigslist
Rickster
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: rickstershemi] #742883
07/08/10 04:56 PM
07/08/10 04:56 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
Only going to run a 27"tire and it will fit without modification....actually from my measuring a 30" tire will fit, just limited on width with the stock spring and no minitub
Rickster
I'm not sure how much different your wheel well is on your car vs. a 69 Dart, but.....
My 69 Dart with a stock width 8.75", stock wheel well and spring location could fit a 15x7" Ramcharger wheel perfectly. Some wheel companies still carry them. I got mine for $45 a piece 6-8 years ago. A dog dish hubcap will cover 3" wheel studs too
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: Dart1031] #742884
07/08/10 04:59 PM
07/08/10 04:59 PM
Hemiroid Offline
Hemiroid  Offline
That little sucker is gonna be cool Just a suggestion, might want to consider B5 blue. I think it would come close to matching the interior and would look great.
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: Dart1031] #742885
07/08/10 05:27 PM
07/08/10 05:27 PM
Rickster
Adam what size tire is that on the back of your car...????? I have done a ton of measuring and can actually get a 15" x 8" rim in there with a 4.675 b/s
Rickster
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: Hemiroid] #742886
07/08/10 05:35 PM
07/08/10 05:35 PM
You just might be right there Marc.....looks pretty close
Rickster
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: rickstershemi] #742887
07/08/10 05:51 PM
07/08/10 05:51 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
What color paint are you thinking?
Not sure on the code yet, but the same color as the interior, I believe it's a medium or light blue metallic....need to find out, when I look at the paint chips online for 64 plymouth the light blue seems too light and the medium blue metallic seems too dark....
If you look at the color of vinyl seat trim in the above pic, it is very close to that
Rickster
Rickster, my vote goes for the paint that is on the car now. Love that old paint.
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: Hot 340] #742888
07/08/10 06:09 PM
07/08/10 06:09 PM
Rickster
OH Hell No.....you'd have to see it up close, it looks like someone tried to paint it with a fence white wash from home depot with a brush and too much patina showing through.....it's definitely getting painted...lol
Rickster
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: rickstershemi] #742889
07/08/10 06:31 PM
07/08/10 06:31 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
Rickster
If you're referring to my sig pic, that's my Valiant(mini tubbed, 11.5x28 Hoosier). My 69 Dart had a 255/75 15 M/T drag radial. I don't have any pics of it with the steel rims or I'd post them.
Now that I think about it, my 8.75" had Moser axles which required B-body brakes. I think the axle was a 1/2" wider each side with the Moser's.
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: Dart1031] #742890
07/08/10 07:13 PM
07/08/10 07:13 PM
Rickster
I'm planning on running either the M/T P255/60/15dr's or the Diamond-Back Redline Nitto's, more than likely the M/T's their easier on the pocket
Rickster
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: rickstershemi] #742891
07/08/10 08:59 PM
07/08/10 08:59 PM
scratchnfotraction Offline
on my 68dart with a-body spec 8 3/4 and moser axles it does make it a 1/2" wider over all..1/4" each side
I ran weld 7x15 with 4.5 back space with a 245/60 15 in the untouched wheel wells and fender lips
fit in the center and had a 1/4" at the fender lip and a 1/4" at the spring and tire bulge
floped the a-body 8 3/4 in the 85 truck and ran the 12" rim with 4.5 bs and the 29x15x15 M/Ts
same 1/4" clearance on the spring and tire bulge and fender lip on the stepside
what has been done to the 8 3/4 in your A-body????
does it have the A-body 1 3/4" brakes or does it have the B-body large brake offset on the axles with the 10" drums and 4" wbp???
dont recall what you said rick..I know it has the long studs,IIRC you said 10" drums
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: rickstershemi] #742892
07/08/10 09:26 PM
07/08/10 09:26 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
Rickster
OK, I meant 255/60. Not 255/75 I've run the Nitto 555's on a few cars and they work good. Mid 11's on a five year old set, lol. Haven't seen the Diamond Backs yet.
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: Dart1031] #742893
07/09/10 09:55 AM
07/09/10 09:55 AM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I went with Spitfire headers. They are shorties and a ton cheaper than TTIs, I think I paid $200 and had them coated for $75.
Spitfire Headers
Harold Johnson
479-650-9989
Ft Smith, Arkansas
Here are a few pics
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: WadeMetzinger] #742894
07/09/10 09:55 AM
07/09/10 09:55 AM
Tulsa, Ok
Tulsa, Ok
another
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: WadeMetzinger] #742895
07/09/10 09:57 AM
07/09/10 09:57 AM
Spitfire Headers
Harold Johnson
479-650-9989
Ft Smith, Arkansas
Here are a few pics
I've heard a bunch of folks were having problems with Harold....????? When did you get yours....?????
Rickster
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: WadeMetzinger] #742896
07/09/10 09:59 AM
07/09/10 09:59 AM
Tulsa, Ok
Tulsa, Ok
another 2
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: WadeMetzinger] #742897
07/09/10 10:08 AM
07/09/10 10:08 AM
Tulsa, Ok
Tulsa, Ok
The winter before last winter of 2008 - 2009. I didn't have any problems with him and I read a lot of the stuff on the internet bad mouthing him too but decided to take a chance since they looked good and were so reasonable. I think I got them in 3 weeks.
Here are a bunch more photos:
http://metzinger.oxentenko.com/66_Cuda/Engine_Final_1.JPG
http://metzinger.oxentenko.com/66_Cuda/Engine_Final_2.JPG
http://metzinger.oxentenko.com/66_Cuda/Front.JPG
http://metzinger.oxentenko.com/66_Cuda/Header_Front.JPG
http://metzinger.oxentenko.com/66_Cuda/Headers_Driver.JPG
http://metzinger.oxentenko.com/66_Cuda/Headers_Passenger.JPG
http://metzinger.oxentenko.com/66_Cuda/Passenger_front.JPG
http://metzinger.oxentenko.com/66_Cuda/SirCuda_Motor.JPG
I have more and close-ups of the headers and exhaust if you want them just email me and I'll send them to you, there are bigger files.
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: WadeMetzinger] #742898
07/09/10 10:25 AM
07/09/10 10:25 AM
Tulsa, Ok
Tulsa, Ok
I used the Schumacher mounts and the Schumacher torque strut as well.
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: rickstershemi] #742899
07/09/10 11:02 AM
07/09/10 11:02 AM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
Spitfire Headers
Harold Johnson
479-650-9989
Ft Smith, Arkansas
Here are a few pics
Rickster
I have a set of used Spitfires (bought in spring of '02) that I ran on mine before stepping up to the Doug's back in '06. They worked a little better than the 340 Hi-Po exhaust manifolds that I had before, but weren't enough to get me anywhere near the 11's.
One piece of advice if you go that route: weld a flange or some kind of attachment bracket to them before getting them coated and installed. I had a heck of time getting the exhaust tubes to stay attached and sealed tight. Wish I would have welded a couple nuts to the sides before Jet-Hot coating them to use as draw-down points. Oh well, live and learn...
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: WadeMetzinger] #742900
07/09/10 02:57 PM
07/09/10 02:57 PM
I plan on making up a strut myself, have a nice pair off the roadster we never used with heim joints and chrome
Nice looking cuda Wade That # for Harold is no longer a working #
I just passed up a set that were on fleabay that went for just under $300 uncoated....not a bad looking piece and I was impressed with the thickness of the flanges, but not too excited how the two tubes dump at a 90* angle into the collector, but for the money...okay I appreciate the help, but will go the full header route down the road, plenty of time to save up
Rickster
Re: {{{{ SMALL VALIANT UPDATE }}}} [Re: rickstershemi] #742901
07/09/10 03:25 PM
07/09/10 03:25 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Rickster
It almost looks like the sides of the seats and the doors are pretty close to b3 blue
