Page 3 of 3 1 2 3
Re: Can I run a mechanical and electric fuel pump? [Re: GTXKen] #74308
06/17/08 03:38 PM
06/17/08 03:38 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
What thermostat are you running now, 160?
Re: Can I run a mechanical and electric fuel pump? [Re: VITC_GTX] #74309
06/17/08 03:58 PM
06/17/08 03:58 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I'm still running a 180, its just a high flow rather than the $2 parts store crap. I don't want to lower the opperating temp for those cold days, don't want to make sludge.
Re: Can I run a mechanical and electric fuel pump? [Re: VITC_GTX] #74310
06/17/08 04:18 PM
06/17/08 04:18 PM
California, USA
blairboy3 Offline
blairboy3  Offline
California, USA
Changing from an Edelbrock (Fuel bowl sits on the manifold) to a Holley (fuel bowl up & away from he manifold) would solve the problem too! Plus, Holleys are better
I have a Holley 750 double pumper on the car now.
I'll read the WHOLE post next time!
1968 Plymouth Fury III 4-Door: 12.79 @ 115, 60'- 1.93 (Hey... it's a Cruise ship... what do you expect?!) Famoso Raceway, 02/08
Re: Can I run a mechanical and electric fuel pump? [Re: GTXKen] #74311
06/19/08 11:44 AM
06/19/08 11:44 AM
GTXKen Offline
super gas
GTXKen  Offline
super gas
My GTX runs hot as well but I didn't use my airgrabber hood and run a 2" spacer.
I am waiting for my new distributer from Don at FBO and I hope that helps. Don thiought it would but obviously it didn't help you.
I just installed a high flow thermastat and that helped a lot. I also moved my fuel line from the stock route to a braided line from the feed to the fender and down to get it away from the block.
I think adding another fuel pump is just masking the problem, a new thermastat is like 10
I'm quoting myself
For the record I got my distributer from Don at FBO 16 initial 35 total, set the timing and then sit the idle mixture and my car now runs at 180 even while running in the garage at 3200 RPM to check full advance, went for a drive and pulled back in the garage and its running at 180. I'm returning the radiator I bought.
I'd take a hard look at your timing. Are you running vaccum advance to help it idle?
Page 3 of 3 1 2 3
