Mopar gurus! build sheet question A-body [interesting]
#74174
06/15/08 08:47 PM
06/15/08 08:47 PM
Posts: 216 Tampa Florida
MoparTod
Tampa Florida
Hello to all and thanks to those whom can help. I recently bought a 1970 Dart Swinger. I was lucky enough to find the original build sheet still in tact. Under line 7 [heavy duty Fleet] under the line police engine I have a code 1 The decoder I have states this was indeed a police engine. It has a 318 2bbl. I would think this would be a bigger and a 4bbl engine. It also lists codes for heavy duty alt, Radio support pkg, battery, spotlight, roof light reinf. codes. Most of the codes dont jive with my decoder. I would think it would be left blank if it were not optioned. It also has a 8 3/4 open diff under it. What do I have here? Is this car special in some way? The broadcast sheet states it was for export. What does this mean. Here are the code numbers if someone can help. police engine-1 alter-8 radio support pkg-3 battery-0 spotlight lft-1 spotlight right-4 roof light reinf-3
Re: Mopar gurus! build sheet question A-body [interesting]
[Re: Alaskan_TA]
#74179
06/16/08 05:30 AM
06/16/08 05:30 AM
Posts: 6,252 Zzyzx Road
beepbeep
moparts member
moparts member
Zzyzx Road
Barry, have you broken out the Victrola yet?
Amazing how an unchallenged lie can become the absolute truth.
[Re: MoparTod]
#74180
06/16/08 07:57 AM
06/16/08 07:57 AM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
What is the VON? (top line) Was it built at Windsor plant? (R in the VIN) What are the Y codes? (Upper right hand corner) What is the engine assembly number (Line 4; left hand side) Any codes in the X section (Bottom row)
A picture or scan would help with your questions.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: MoparTod]
#74187
06/16/08 11:33 PM
06/16/08 11:33 PM
Posts: 29,650 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I thought these sheets were the gospel on the car it represents. Thanks Tod
Not always, look here for some mistakes;
http://www.hamtramck-historical.com/factoryErrors.shtml
I have to admit, the second to the last entry on page four is absolutely my favorite broadcast sheet error by far. So far......
[Re: dogdays]
#74188
06/16/08 11:35 PM
06/16/08 11:35 PM
Posts: 4,150 lewiston, ID
cornucopia
lewiston, ID
I have a 1970 dart build sheet from Windsor...I bought, drove and parted the car out back in 90/91...it was a tad special; it was a city,fleet car...said "special equipment order" right on the b-cast sheet...wierd car; 4-door,318,727, 4 core radiator with shroud,8 3/4 with 3.23s,sway bar,radio delete,coded for big alt and battery, right side mirror...but otherwise a rubber mat stripper... I still have the fender tag and b-cast sheet. if you need more info, let me know!
[Re: 69CoronetRT]
#74191
06/17/08 01:06 AM
06/17/08 01:06 AM
cornucopia
lewiston, ID
I'd like to see that one.
I don't have my scanner online, but here is the tag: Ew1 F11 Y05 END Ew1 L2X9 TX9 304 Jo1895 E44 D31 LL41 GoR 228485
I have the b-cast sheet handy...ask me any questions. it had a sticker in the door jam that said "city of Tukwila" (washington)
