Manual Steering Fluid? #74110
06/15/08 03:24 PM
06/15/08 03:24 PM
USA
stan1970 Offline OP
stan1970  Offline OP
USA
Greeting Moparters -
on a 1970 manual steering B-Body -- are there fluid/gear oil levels to check for a manual steering box?
I used to think there was no fluid associated w/ manual steering, but recently heard someone mention that they do in fact have fluid and should be maintained??
Is this so? And if so, where do I check the level and what type of fluid should I be using? (1970 B-Body).
Much thanks for any tips.
--Stan
Re: Manual Steering Fluid? [Re: stan1970] #74111
06/15/08 03:49 PM
06/15/08 03:49 PM
The Service manual states to use SAE 90 Gear Oil in the manual Steering box, and it just says, "Lubricant should cover worm gear".
Hope that helps
Re: Manual Steering Fluid? #74112
06/15/08 03:54 PM
06/15/08 03:54 PM
It also mentions NOT to use a pressure gun, as the high pressure may damage the seals. Just get a little funnel, and pour it directly into the filler plug hole.
