Re: Charging a dead a/c system....how??
[Re: BarryBum]
#74047
06/15/08 02:24 PM
06/15/08 02:24 PM
Posts: 1,021 Chesapeake Va
BobK
Chesapeake Va
You need to hook a vacuum pump up to the system and keep it running for quite a few hours to get any traces of air & moisture out of the system. Another thing to do before hooking up the vacuum pump is to pressurize the system with air and check for leaks. You will probably find a few seals that are leaking.
1964 Plymouth Fury x 2 1964 Plymouth Sport Fury
