Negative battery cable #73789
06/14/08 08:26 PM
06/14/08 08:26 PM
Myrtle Beach, SC formerly the ...
340wedge Offline OP
340wedge  Offline OP
I'm replacing my negative battery cable with a reproduction. My old cable was an aftermarket one-piece. The Repro has a pigtail on it, (340 cid) does anyone know what that grounds too? Thanks
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Negative battery cable [Re: 340wedge] #73790
06/14/08 08:45 PM
06/14/08 08:45 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
usually radiator support.
Re: Negative battery cable [Re: 05dakota] #73791
06/14/08 08:52 PM
06/14/08 08:52 PM
340wedge Offline OP
340wedge  Offline OP
Thank you..would it be to one of the bolts that bolts the radiator to the support or a seperate location?
Re: Negative battery cable [Re: 340wedge] #73792
06/14/08 09:01 PM
06/14/08 09:01 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
usually a seperate bolt that has other grounds on it.
Re: Negative battery cable [Re: 05dakota] #73793
06/14/08 10:00 PM
06/14/08 10:00 PM
340wedge Offline OP
340wedge  Offline OP
Thanks again
