Brass block on an 8 3/4 rear #73786
06/14/08 08:23 PM
06/14/08 08:23 PM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
I'm in the process of completely redoing the brake system on my 1967 Dodge Coronet R/T. I'm wondering the correct way to remove the brass brake block from the rearend. I have a new disc brake block that I got with the stainless steel lines. This is the reason why I'm planning on changing them. I'll be grateful for any information.
Thanks !
Re: Brass block on an 8 3/4 rear [Re: 440727] #73787
06/14/08 08:53 PM
06/14/08 08:53 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
unscrew the bolt that holds it on...
I am truckless..
Re: Brass block on an 8 3/4 rear [Re: 440727] #73788
06/14/08 09:42 PM
06/14/08 09:42 PM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
Disconnect the lines first, the bolt will hold the distribution block for you. Then back the bolt on the block out. It's a little deceiving as the bolt goes down thru the block into the housing.
