Master cylinder help
#73580
06/14/08 04:16 PM
06/14/08 04:16 PM
Posts: 650 Kansas
racincuda
Kansas
Well i hav been reedin other posts on master cylinders and it would seem that the one I just brought home is not gonna work all that well Car is 69 Cuda w/74 discs up front & rear drums 340 powerd street car. Th RB master I brought home has a 1 3/32 bore, wat I have read indicates this large bore will require weight lifter legs to stop the car So I am wondering wat others are using ? Please include orig application YR and Model, you kno how those parts house guys are dont cha
Re: Master cylinder help
[Re: racincuda]
#73581
06/14/08 04:28 PM
06/14/08 04:28 PM
RapidRobert
'65 dart w 73 & up factory discs,10" rear drums,used a new '79 D100 truck MC that had IIRC with either a 1&1/32" or a 1&1/8" bore.Manual,no power. It's a pretty hard pedal compounded by the fact that I did not use the adapter plate to mount the MC as I just cobbled this together for a daily beater & the pedal is too high but I've gotten used to it(sort of). but if I did ANY spirited driving it would not be safe enough.
[Re: racincuda]
#73589
06/14/08 09:01 PM
06/14/08 09:01 PM
RapidRobert
1&3/8" bore: man I bet that would be a rock hard,virtually no travel pedal. For a retainer I used a piece of vac hose that looked identical to an original one that I had in my stash except for the groove along the length of the orig one. I'm good so far,Doctor diff do you see any problems with using that for a substitute. .
[Re: DoctorDiff]
#73591
06/14/08 11:06 PM
06/14/08 11:06 PM
RapidRobert
Doc does it need the adapter to lower the pedal height like the other alum ones or is there another issue?
