'69' B-BODY UPPER CONTROL ARM??? #735827
06/28/10 05:55 PM
06/28/10 05:55 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Just got a call from Jake's Automotive,not good news! Need a new driver-side upper control arm on the GTX! They tried to find one a few weeks back...without any luck! Mancini sells them in a kit,but won't separate! Can't blame them! The kit is $300.00,and I'm on a TIGHT budget! Does anyone know where I could get one at a reasonable price??? I'd be VERY GRATEFUL for any help with this matter!
Re: '69' B-BODY UPPER CONTROL ARM??? [Re: Labratt] #735828
06/28/10 06:23 PM
06/28/10 06:23 PM
ohio
all spooled up Offline
ohio
try bondo bob bobsprofab
Re: '69' B-BODY UPPER CONTROL ARM??? [Re: all spooled up] #735829
06/28/10 08:13 PM
06/28/10 08:13 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Randy,
Found this in the May 2010 70 and back B body parts for sale,,,,look in the middle of the ad, I put some **** near it to locate it.....
He mentions some control arms for sale,,$60/pair,,,,
I also put the link at the bottom,,,,
hope this helps.....
Doug
440fied
Reged: Jul 17 2005
Loc: Doo-Dah, KS Free delivery to Chryslers at Carlisle [Re: Bishop]
#6012300 - Mon May 31 2010 12:24 PM Edit Reply Quote Quick Reply
63-65 B-body V8 K-frame $125
66-67 B-body V8 K-frame with sway bar, LCA's, and manual box $400
68-69 B-body V8 K-frame with sway bar and LCA's, big block mounts and skid plate $550
70 B-body V8 K-frame with sway bar and LCA's, big block mounts, and skid plate $550
62-72 B-body Front 10" drum brake spindles and brake hubs, L & R sides $60 pair.
62-72 B-body upper control arms $60/pair. ************************************************************************************************************************************************************************************
62-72 B-body lower control arms (w/o sway tabs) $60/pair.
67-72 B-body 11" front drum assemblies complete L & R (drums, spindles, hubs) $200/pr
62-65 B-body strut rods $40/pair.
66-72 B-body strut rods $50/pair.
62-72 B-body 10" spindles and brake hubs $75/pr
63-65 B-body center links $25
66-70 B-body center links $25
1970 Roadrunner, GTX, Charger R/T or Superbee front disc brakes (spindles, rotors, hubs, calipers) need rebuilt $250
65 B-body floor shift power steering column $125
70 Road Runner, GTX, Charger, Superbee floor shift power steering column $250
Parts are located in Wichita, KS. PM me here for pics or info.
Free delivery to Chryslers at Carlisle, Swap spaces L155-L158 & M156-M159
https://board.moparts.org/ubbthreads/showflat.php?Number=6011987
