alt wiring compared to old. Durango engine in a 65. #73576
06/14/08 04:15 PM
06/14/08 04:15 PM
Andrewh Offline OP
Andrewh  Offline OP
So I am dropping a durango motor into my coronet.
I am looking at the wiring diagram and have a few questions.
The alt is wired to generator field and generator source.
What is that equivalent to in a round back or even square back wiring?
That is are those both the same as the field wires on a square back and if I ground one, will it work with the 65 regulator?
Or do I have to switch up to the 74 and up regulator? Because that doesn't look any better. That diagram shows both field circuits tapping off the same place for voltage.
Re: alt wiring compared to old. Durango engine in a 65. [Re: Andrewh] #73577
06/14/08 05:22 PM
06/14/08 05:22 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
That's like the 70s and up 2 field alternator. You could ground one and use your original regulator, but I would probably just upgrade to the newer regulator.
Re: alt wiring compared to old. Durango engine in a 65. [Re: FuryUs] #73578
06/14/08 06:06 PM
06/14/08 06:06 PM
Andrewh Offline OP
Andrewh  Offline OP
well, it is the electronic voltage reg, so I am not worried about that.
Same deal? Doesn't matter which one you ground?
Re: alt wiring compared to old. Durango engine in a 65. [Re: Andrewh] #73579
06/14/08 07:19 PM
06/14/08 07:19 PM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
i upgraded my charging sys. from the round back to the square in my 65 cuda. then read on here about the new mopar alt. were better so i went to the YJ and took one off a 95 intrepid. hooked it up to the same voltage reg. worked fine.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers
GarysMocars Legendary Dealer
