Tach adaptor question: #73495
06/14/08 12:58 PM
06/14/08 12:58 PM
Costa Mesa, CA
chache876 Offline OP
Costa Mesa, CA
Okay so I've recently installed a mallory hyfire VI-AL igniton box and a sunpro super tach 2 and the tach is not working. I'm assuming I'll be needing a tach adapter to get it to work right (all connections are good) but I see on summit racing there is a $30 adapter and a $110 adapter...what the difference and what should I use?
Re: Tach adaptor question: [Re: chache876] #73496
06/14/08 02:58 PM
06/14/08 02:58 PM
San Jose, CA
Blue69Charger Offline
San Jose, CA
I think you need the expensive one for electronic ignition with a magnetic trigger and the cheaper one for points. If you need the expensive one you can use the MSD 8920 tach adapter which is around $50 with free shipping on amazon. I'm using the msd adapter with a hyfire VI-A with no problems.
Re: Tach adaptor question: [Re: Blue69Charger] #73497
06/14/08 11:31 PM
06/14/08 11:31 PM
Costa Mesa, CA
Costa Mesa, CA
Yeah I am using the oem electronic distributor so that means I'll have to go with the more expensive one correct?
Re: Tach adaptor question: [Re: chache876] #73498
06/15/08 10:07 AM
06/15/08 10:07 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
get a better tach... that Sun is more than likely 1000 RPM off anyway..
I am truckless..
