Small block a body guys...lets see your electric fan.. #73473
06/14/08 12:55 PM
06/14/08 12:55 PM
Costa Mesa, CA
chache876 Offline OP
Costa Mesa, CA
Ive got a 360 72 dodge demon and was curious to find out what you other guys are running for electric fans...so what size, cfm rating, thickness and is it a pusher or puller fan?? Thanks!
Re: Small block a body guys...lets see your electric fa [Re: chache876] #73474
06/14/08 10:25 PM
06/14/08 10:25 PM
Costa Mesa, CA
Costa Mesa, CA
ttt
Re: Small block a body guys...lets see your electric fa [Re: chache876] #73475
06/15/08 08:03 PM
06/15/08 08:03 PM
Costa Mesa, CA
Costa Mesa, CA
okay so I'm thinking about pulling the trigger on a Proform 10" reversible fan that puts out 1000 cfm. Would this be enough to cool a small block street 360 (stock)? I think the 1000cfm would be enough but is the fan itself to small? Should I go owith a 12"?
Re: Small block a body guys...lets see your electric fa [Re: chache876] #73476
06/15/08 09:31 PM
06/15/08 09:31 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
I use an electric fan and water pump on the Dart drag car. It does ok but I think it would slowly overheat in traffic if it were a street car.
I'm looking into this
http://www.jegs.com/i/JEGS/555/52065/10002/-1
It's a shroud for an electric fan that I think would help alot by allowing the fan to pull air through the entire radiator instead of just the size of the fan.
Sorry, no pics
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Small block a body guys...lets see your electric fan.. [Re: chache876] #73477
06/15/08 10:26 PM
06/15/08 10:26 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
31"x19" rad with twin 12" fans pulling 2500cfm
Re: Small block a body guys...lets see your electric fa [Re: chache876] #73478
06/15/08 10:49 PM
06/15/08 10:49 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
1000 CFM isn't going to cut it. You need more like 3-4000 CFM - no, really - to keep a healthy engine cool on the street. Yeah, that can cost a lot if you go aftermarket, but there are LOTS of junkyard options. The OEM's aren't going to cheap out on a cooling fan, and you can benefit from their hard work. There are lots of threads on electric fans, so you might try searching for something like "Lincoln fan" or "Mark VIII" for some good ideas. I know OzHemi had a very detailed thread on how he installed a Mark VIII fan in one of his cars. Late 90's t-birds also used a similar fan, and Taurus/Sable fans are also nice pieces.
My personal fan is from an early 2000's Volvo sedan:
That fan is EASILY 3000 CFM, maybe more. It draws some amps though, so be prepared to upgrade some wiring - especially through the bulkhead connector - when you do an electric fan install.
Clair
Re: Small block a body guys...lets see your electric fa [Re: Clair_Davis] #73479
06/15/08 11:04 PM
06/15/08 11:04 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
The one I used was a Tbird one actually..from a '96 4.6L car. It fits the 27" Summit radiator Perfectly as well
It's a 2 speed fan, and I had it wired so as the low speed came on with a sensor (in the intake, to come on at 180) and the high-speed on the fan on a switch.."just in case" but even in the middle of the summer I could let the car idle for 45 minutes and it would not get over 190 degrees
Here it is as I was mocking up the mounts and wiring..
Re: Small block a body guys...lets see your electric fa [Re: OzHemi] #73480
06/15/08 11:45 PM
06/15/08 11:45 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
I found a nice taurus/sable electric fan/shroud for $25.00 at the junky.... It tested and worked great. I measured it for mounting behind my 27" summit rad and the fan was 1/2 to deep. It hit the water pump snout on my J-body TBF
Re: Small block a body guys...lets see your electric fa [Re: tpabayflyer] #73481
06/15/08 11:52 PM
06/15/08 11:52 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Trim it down a little bit
Re: Small block a body guys...lets see your electric fa [Re: tpabayflyer] #73482
06/16/08 12:02 AM
06/16/08 12:02 AM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
U velly clever grasshoppa..... I just might bust out the recip saw and do some trimming!!!! Is that a sable fan you are using??? The one I have really kicks butt, but I bet it pulls some amps.... I see the bosch relays and wonder how you wired yours up?? Do you have another thread about your fan install??? If so please post a link as I will get busy tomorrow morning.
I also like your mounting solution for the fan, very nice.
TBF
Re: Small block a body guys...lets see your electric fa [Re: tpabayflyer] #73483
06/16/08 12:06 AM
06/16/08 12:06 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I did a big thread on it ages ago when I did it (been a couple years now I think? )
It's a Tbird 4.6l fan actually
On the relays..read what I wrote a little further up about the 2 speeds on the fan..I used one relay for each speed on the fan
Re: Small block a body guys...lets see your electric fa [Re: OzHemi] #73484
06/16/08 12:07 AM
06/16/08 12:07 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Re: Small block a body guys...lets see your electric fa [Re: OzHemi] #73485
06/16/08 12:08 AM
06/16/08 12:08 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Re: Small block a body guys...lets see your electric fa [Re: OzHemi] #73486
06/16/08 12:09 AM
06/16/08 12:09 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Re: Small block a body guys...lets see your electric fa [Re: OzHemi] #73487
06/16/08 12:12 AM
06/16/08 12:12 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
BTW...you'll notice the blade off in most of the pics
It is amazing how sharp those plastic blades can be on them things, so all the mock up work was done sans-blade.
Re: Small block a body guys...lets see your electric fa [Re: OzHemi] #73488
06/16/08 12:14 AM
06/16/08 12:14 AM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
Thanks a bunch.... very clean install... TBF
Re: Small block a body guys...lets see your electric fa [Re: tpabayflyer] #73489
06/16/08 12:17 AM
06/16/08 12:17 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Happy to help
Re: Small block a body guys...lets see your electric fa [Re: OzHemi] #73490
06/16/08 09:52 AM
06/16/08 09:52 AM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
To the 27" summit radiator dudes, how did you handle the mounting? I like the 4.6 ford fan deal. Looks like a nice package! Can you give the part# for that rad?
2014 Durango R/T
2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed
1998 Dodge Durango SLT 5.2
1971 Plymouth Duster-
<<<<<MOPAR SPOKEN HERE>>>>>
Re: Small block a body guys...lets see your electric fa [Re: WayneM] #73491
06/16/08 11:33 AM
06/16/08 11:33 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Just had my buddy weld on 4 flanges (I didn't have aluminum stuff for my mig) and I bolted it to the core support...you can see one in this pic, to the left of the relays
(I've mounted them the same way on 3 vehicles now..and going to be using another one shortly )
Don't remember the part number off hand, would have to look it up
Re: Small block a body guys...lets see your electric fa [Re: OzHemi] #73492
06/16/08 03:11 PM
06/16/08 03:11 PM
Kansas
racincuda Offline
racincuda  Offline
Kansas
Great job OZ, looks great I am going to try a fan & shroud from an early Horizon As soon as I get brakes and Valves adjusted
Re: Small block a body guys...lets see your electric fa [Re: racincuda] #73493
06/16/08 06:24 PM
06/16/08 06:24 PM
Costa Mesa, CA
Costa Mesa, CA
It seems all or most of you are running an aftermarket 27" radiator, while I've got a stock (22"?) radiator and I dont think any of those fans would come close to fitting
Re: Small block a body guys...lets see your electric fa [Re: chache876] #73494
06/16/08 07:03 PM
06/16/08 07:03 PM
NH
72challorange Offline
He's Game
He's Game
NH
The aftermarket radiator is 27" from outside tank edge to outside tank edge. Yor factory 22" is the core width, they might be close to the same core size. I think mine was 22x18 core size IIRC this is the summit (northern Rad).
Tom
