Weird question about Generic motors swap. #73452
06/14/08 11:15 AM
06/14/08 11:15 AM
Rochester, NY
dusterdood Offline OP
Rochester, NY
I'm talking my buddy into swapping in a spare '66-'70 B body 8 3/4 that I've got under his '79 Firebird. The stock rear is 55.25" flange to flange, and 45 3/8" perch to perch. Anyone see a reason the 44" perch to perch B housing wouldn't work with off set shackles on the rear? That corporate 10 bolt junk needs to go.
As a side note. I told him to use elephant ears to swap a 440 in there. Anyone know of headers that would be a fit?
Re: Weird question about Generic motors swap. [Re: dusterdood] #73453
06/14/08 12:07 PM
06/14/08 12:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What are you gonna do for rims? Bolt patterns are different.
As for offset shackles, why not.
Don't be the exception.
Re: Weird question about Generic motors swap. [Re: dusterdood] #73454
06/14/08 12:54 PM
06/14/08 12:54 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Check the pinion offset. I'm not sure if GM had the pinion offset or not.
Sheldon
Re: Weird question about Generic motors swap. [Re: RUNCHARGER] #73455
06/14/08 01:17 PM
06/14/08 01:17 PM
any possibility that you could just persuade him to purchase a nice running hot Mopar? That would convert him quicker than anything. I bought my first Mopar in '75 a '68 GTX convertible 440 sp 4.10 dana & was hooked instantly,forgot about the chebrolet's & never looked back.
Re: Weird question about Generic motors swap. [Re: RapidRobert] #73456
06/15/08 08:00 AM
06/15/08 08:00 AM
Rochester, NY
Rochester, NY
Guy's a douche, but a friend. Unfortunately, he's convinced that the shock mounting would be an issue, and he's keeping the 10 bolt.
Re: Weird question about Generic motors swap. [Re: dusterdood] #73457
06/15/08 08:51 AM
06/15/08 08:51 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
other than the different bolt pattern wheels i don't know why it can't be made to work. they put 8.8 ford rears in mopars for the rear disk brakes, dana 60 and ford 9" under everything. it could be a cheap gear change rear over buying a custom made ford 9".
perception is 90% of reality
