Re: Cork or Rubber? Tranny pan gasket.. STILL LEAKS [Re: Pacnorthcuda] #733643
09/04/10 01:31 PM
09/04/10 01:31 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Many a pan gasket has been blamed for leaks that actually come from:
The selector shaft seal
The Fill-tube/O-ring
The reverse-shaft at the rear of the pan area, just above the pan rail
Exactly.
Re: Cork or Rubber? Tranny pan gasket.. STILL LEAKS [Re: 1_WILD_RT] #733644
09/04/10 02:30 PM
09/04/10 02:30 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I always have a tendency to over tighten so cork is always out for me. On my daughters neon I used "the right stuff" and no gasket but usually I just use a rubber gasket. Her neon leaked no matter what I tried so I used the sealer only. As far as the filler tube leaking, reach up around the base of the tube and see if it is wet. The fluid isn`t going to drip uphill.
Re: Cork or Rubber? Tranny pan gasket.. STILL LEAKS [Re: 1_WILD_RT] #733645
09/04/10 04:33 PM
09/04/10 04:33 PM
BDW Offline
BDW  Offline
Exactly.
Good advice, as I said, replaced my pan/gasket 3 times. Look elsewhere.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: Cork or Rubber? Tranny pan gasket... [Re: cuda_tim] #733646
09/04/10 05:35 PM
09/04/10 05:35 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
I had a turbo350 in my 69 Camaro that we couldn't get to stop leaking. No matter what gasket we used. Checked the pan and it was a little bent around the bolt holes so we fixed it. Still leaked. Bought a new deep pan and it still leaked. Finally put a straight edge on the trans itself and found that it wasn't flat. After asking around, I was told that if somebody had taken a metal scrapper, lik a putty knife, to clean the rail, it's easy to cause this type of problem. We took a long file and carefully worked the area around the low spot and finally got it to even out a bit. Put it back together and no more leak. May be worth checking into.
Re: Cork or Rubber? Tranny pan gasket... [Re: None2Slow] #733647
09/23/10 12:12 AM
09/23/10 12:12 AM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
Ok, I took my deep pan off again. And I thought that I found the problem. I was so excited!
When I laid a straight edge across the front of the pan rail (the rail that meets the front of the tranny), there appeared to be a little bend... exactly where it leaks (on the passenger side front corner). That was the only place that it didn't appear to be straight.
So rather then try to straighten it (and perhaps make it worse), I bought a new pan.
But this one appears to be bent in the same area.
So I'm ready to sell the car. Any takers? (just kidding!)
Now I'm thinking that I have a couple of options. 1) try and straighten the old one or 2) try the new one as is.
It came with a new rubber gasket that is less than 1/8" thick.
Does anyone know, am I supposed to use any sealant?
Thanks!
Tim...
"Robots building robots.... now that's just stupid!" - Will Smith in the movie "I, Robot".
'71 Demon (340/727)/'69 Charger (383/727)/'65 Barracuda (273-2V/904)/'66 Coronet (340/727)/'86 Dodge Aries (2.5L)/'78 Dodge Aspen (318-2V/904)
Re: Cork or Rubber? Tranny pan gasket... [Re: Reggie] #733648
09/30/10 01:14 PM
09/30/10 01:14 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Go to a Dodge/Chrysler dealer and get the newer style reuseable pan gasket. The number for the 727 (or A-518/46RH/46RE) is: 2464324AC.
My local Dodge dealer indicates this is no longer a valid number.
Anybody got the current part number for the reusable 727 gasket?
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
