Engine miss on new engine
#73250
06/13/08 05:39 PM
06/13/08 05:39 PM
Posts: 123 usa
DLP4
usa
472 HEMI, MP Alum heads, JE 10.5:1, Eagle 4.15 stroke, CompCams solid grind 285S-8, 250/250 @ .50. .557/.540 lift at valve with stock rockers, 108 LSA, M1 intake, Holy 4150 vac secondary 0-80531 with 78 primary jets, 82 secondary, orange box ignition, MP distributor, Accel super-stock coil.
I'm having trouble figuring out why I have a miss on acceleration. It's a street car. It idles fine and drives ok but has a bad miss when I romp on it. Plugs look tan. I've got 1/2" fuel line with an electric pump and return-type regulator.
What should I be looking at?
Re: Engine miss on new engine
[Re: DLP4]
#73253
06/13/08 09:37 PM
06/13/08 09:37 PM
Posts: 20,726 A collage of whims
topside
A collage of whims
I would suspect that the air cleaner base is interfering with something on the carb, or is grounding or arcing at the distributor cap or wires, if removing it cures the problem. I wouldn't think even a VERY small or restrictive air cleaner would cause a miss; lack of airflow would act more like an RPM or power limiter, where the motor stops pulling. More info on the carb might help: power valve, shooter size, float settings - a 78 primary jet sounds small for 572" and that size cam, but I could be wrong; you indicated that the plugs have color. Then again, idling will color-up spark plugs, where full throttle & cutting the engine will give a more accurate reading - look down a ways at the sides of the porcelain. Another thing to look at is the timing. Is it a miss like 1 cylinder & rhythmic, or scattered misfire, detonation ("rattling"), or ???
[Re: topside]
#73254
06/14/08 07:51 AM
06/14/08 07:51 AM
RapidRobert
arcing over to the air cleaner
[Re: DLP4]
#73257
06/14/08 09:38 PM
06/14/08 09:38 PM
topside
A collage of whims
I sthere clearance between the air cleaner lid & the bowl vents? Look for clearance at the needle & seat adjusters, throttle linkage, secondary linkage, fuel line if you're running hose. So, it runs fine without an air cleaner, but installing it acts like a rev limiter, breaking up at 4,000 and shutting it down to 3500, and then it runs fine? Or does it continue to strangle until you remove the air cleaner & restart the motor? What's this air cleaner look like?
