oiling with solid roller rockers #73151
06/13/08 12:12 PM
06/13/08 12:12 PM
New Hampshire
W
whitemtnelf Offline OP
W
New Hampshire
Are any mods needed to get the correct oiling up to the rockers when using solid roller lifters on a 440?
Re: oiling with solid roller rockers [Re: whitemtnelf] #73152
06/13/08 01:20 PM
06/13/08 01:20 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Not as long as the block is still feeding the rocker shafts like the factory built them.
Re: oiling with solid roller rockers [Re: buildanother] #73153
06/13/08 04:03 PM
06/13/08 04:03 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Correct. Also make sure the after market shaft has slightly enlarged holes where the oil goes into it. The bolt takes up some of the space so the hole has to be a little larger on that one(both sides). Make sure shaft has the holes pointed down when installed. -Bob
Re: oiling with solid roller rockers [Re: BobR] #73154
06/13/08 05:45 PM
06/13/08 05:45 PM
New Hampshire
W
W
New Hampshire
Re: oiling with solid roller rockers [Re: BobR] #73155
06/14/08 12:19 AM
06/14/08 12:19 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Good tip, same for rocker shaft shims.
