Re: Smallblock in a Caravan
[Re: Runnin74]
#731348
06/25/10 11:52 PM
06/25/10 11:52 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I don't know about the earlier model Caravans, But the 2001 and up models have no tranny tunnel - just flat floorboards. I suppose if one was going to the effort to put in a small block that wasn't a mid mount you could graft in a tunnel.
Start with an AWD minivan, they have a driveshaft, rear axle and flat floors..
[Re: Dakota_Don]
#731351
06/27/10 03:58 AM
06/27/10 03:58 AM
Posts: 4,131 Canada -- Posts: 4034 -Registe...
5thAve
somone here had a van wit a SB, if i remember right he used a dipy k frame, and the rear axel.
I guess you missed the other replies that mentioned that and the engine picture
[Re: elmor]
#731353
06/27/10 11:53 AM
06/27/10 11:53 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
What type of rear axle did the AWD Caravans have in them? That does sound like an interesting concept. I would love to build a mid-engine rig, but I'm concerned with having enough room for a good pinion angle. If I set the engine/trans in back of the front seats, that doesn't leave much room for a driveshaft, if any. A 3 inch driveshaft doesn't make for very good angles or allow for rearend movement.
Just thinking out loud here, but one way to deal with that is to run an IRS and have the center section solid to the unibody. It would not be a wheelie machine or a dragstrip terror, but you could make it handle.
[Re: MarkZ]
#731355
06/27/10 12:02 PM
06/27/10 12:02 PM
Posts: 4,366 Michigan
MarkZ
Worthy
Worthy
The sub-frame is for a 440 powered A100 wheelie stander. You could use this concept for a mid-engine mount in a Caravan.
[Re: MarkZ]
#731356
06/27/10 01:21 PM
06/27/10 01:21 PM
Posts: 1,680 Raleighwood
2Bad360sfromNC
Raleighwood
Sounds like a whole lot of work when the 4 cylinder turbo Caravans can do this with a lot less work... http://www.youtube.com/watch?v=GhcOBrsk0nc...but it would be kinda neat and sound better.
1968 Charger project. I don't have a fender tag or a buildsheet, so it's getting a 440. Help me decide on a color--most everything looks great! (NOT white. My Challenger is white. Need some variety :D) 1974 Challenger 360 2012 Challenger R/T 1991 Dakota 5.2
[Re: RodStRace]
#731358
06/27/10 02:16 PM
06/27/10 02:16 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
My suspicion would be that whatever rearend an AWD Caravan would have would be too weak. I'd stay with my recommendation of a Ford Explorer 8.8 - cheap, Locker can be prelim-identified on the door tag, and has disk brakes.
Midship mount does not leave much room for a driveshaft. I wondered if a motorhome 727 would help, but it's probably not much different than a 904.
My 'new idea' would be to install an 8.8 IRS from a Lincoln Mark 8. Solid mount it into a subframe as Rod St Race and Mark Mullins have mentioned.
[Re: RodStRace]
#731359
06/27/10 02:39 PM
06/27/10 02:39 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
3rd Gen Supras ('86.5-'92) are IRS rears mounted on subframes which have the whole shebang - pumpkin, suspension, a-arms, springs, struts, the works. Might not be too difficult to adapt to the existing structure. And the rear end is quite stout. LSDs can be found and gears available are 3.73, 3.91, or 4.30. Some guys have run 600HP at the crank through that diff.
Probably wouldn't be too hard to find, since most of those cars are wrecked in the front.
