Page 6 of 6 1 2 3 4 5 6
Re: More Engine Problems #72998
06/19/08 06:24 PM
06/19/08 06:24 PM
Simi Valley, CA
MoparJ Offline
MoparJ  Offline
Simi Valley, CA
Dr. Phill in the house I see. anyways,
the way i see it.. he's getting to many different responces here
to be of any help, hence chasing his tail. IF he really wants to learn. get a good rebuild book, take your time
and if your stumped.. ask here.
"DO OR DO NOT... THERE IS NO TRY!"~ yoda (wise green thing)
No Dr. Phil here; I cannot stand that hypocrit. Lmao. Cmon', if I wasn't level headed, I may have been insulted by that comment, but afterall, this is just a forum. Just trying to speak with a little reason and help him out,sir. I do agree with now being the time to take the thing to a REPUTABLE shop, since we have exhausted everything trying to help him out.
don't mis-interpret my sanctimonious, obtuse responces.. embrace them.
PS,
good move bordin34
LOL.....hahaha, if you say so...
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: More Engine Problems [Re: MoparJ] #72999
06/19/08 06:37 PM
06/19/08 06:37 PM
PS,
good move bordin34
i believe i just did...
Re: More Engine Problems #73000
06/19/08 06:39 PM
06/19/08 06:39 PM
Simi Valley, CA
MoparJ Offline
MoparJ  Offline
Simi Valley, CA
PS,
good move bordin34
ok
Re: More Engine Problems [Re: MoparJ] #73001
06/19/08 11:42 PM
06/19/08 11:42 PM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
One more thing to check, the Timing chain. If that sucker hasnt been replaced it probably has a mile of clearance right now. That can cause all sorts of problems and it can jump time. Not to mention the plastic breaks off the gear and can cause a clogged pickup tube. Is it backfiring out the exhaust or the carb?
Also when you crank it does it sound like R-R-R-REEER-R-R-REEER like it has a spot where it wants to spin faster for a moment? If it does that thats usually an indication that a valve is dropped. There is low ompression on that cylinder and the starter speeds up because of that.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: More Engine Problems [Re: bordin34] #73002
07/01/08 08:28 PM
07/01/08 08:28 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Just wondering what you found out on your car.
Re: More Engine Problems [Re: Posest] #73003
07/02/08 02:12 PM
07/02/08 02:12 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
I took it to the shop and I am away right now but my mom said that the guy set the timing and did some carb adjustments. He said he is still trying to track down why it runs badly when cold.
