lost oil pressure. #72837
06/13/08 09:34 AM
06/13/08 09:34 AM
Anonymous OP
Anonymous OP
I was out playing with my roadrunner last night and went from a dead stop on a country road up through the gears pretty hard, car ran awesome sounded great. I got to the highway, car acted fine, ran down the hiway about a mile with no problems, pulled into the parking lot at work to drop a buddy off and drove around the building back to the hiway and while I was sitting there waiting on traffic the oil pressure light kicked on, so I back up out of the way and the car went to chattering in the valvetrain so I shut it off. What could have happened here?? The car ran great, then idling to a stop I lose oil pressure.
oil pump drive gear? oil pump? spun bearing? I never heard rods it was all valvetrain.
btw its a pretty fresh motor if that helps.
Re: lost oil pressure. #72838
06/13/08 10:01 AM
06/13/08 10:01 AM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
Happened to me way back when. Same senario....sitting and lost oil pressure. It was the oil pump....under warrenty...towed to dealer and back to me in 3 hours. Many things this could be but this did happen to me.
Re: lost oil pressure. [Re: BELVEDERE67] #72839
06/13/08 10:10 AM
06/13/08 10:10 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Oil pump drive shaft. (intermediate shaft) Popped a lifter out of the bore. If this is what happened you will still have had oiling to the rods and mains but not to to the top.
Re: lost oil pressure. [Re: MoparforLife] #72840
06/13/08 10:23 AM
06/13/08 10:23 AM
Anonymous OP
Anonymous OP
sounds right.
Re: lost oil pressure. [Re: MoparforLife] #72841
06/14/08 10:41 AM
06/14/08 10:41 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Or bent push rod let a lifter pop out of the bore?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: lost oil pressure. [Re: GO_Fish] #72842
06/16/08 10:10 AM
06/16/08 10:10 AM
Anonymous OP
Anonymous OP
oil pump locked up and snapped the intermediate shaft, installed a new melling pump and a new shaft with no problems car runs great.
Re: lost oil pressure. #72843
06/16/08 10:17 AM
06/16/08 10:17 AM
scratchnfotraction Offline
did u find anything in the pump?
what would lock it up if it did not suck trash?
was it scared up or galled on the rotores/housing?
was u low on oil after it stoped pumping?
glad it was a easy fix..but just wondering what would cause this
every one that I did I found something in the pump to lock it up..small and big block
Re: lost oil pressure. [Re: scratchnfotraction] #72844
06/16/08 06:03 PM
06/16/08 06:03 PM
Anonymous OP
Anonymous OP
looks like the clover leaf shaped rotor had too much play compared to my new one, because one side was wedged in where it didn't mesh properly.
I only found one large metal shaving in the pump itself, looks like its from the rotor or housing.
Re: lost oil pressure. [Re: scratchnfotraction] #72845
06/16/08 06:05 PM
06/16/08 06:05 PM
Anonymous OP
Anonymous OP
oil level was a little past the full line as usual, its a fresh motor no trash, I changed the oil again and everything looks great.
Re: lost oil pressure. #72846
06/16/08 06:20 PM
06/16/08 06:20 PM
I'm glad you had the discipline to shut it off fast
Re: lost oil pressure. [Re: scratchnfotraction] #72847
06/17/08 10:19 AM
06/17/08 10:19 AM
Anonymous OP
Anonymous OP
looks like they may have put a used pump on my new shortblock.
