Need :PS Pump Pulley Dia. for 70 440-6 pk #72818
06/13/08 08:14 AM
06/13/08 08:14 AM
Anonymous OP
Anonymous OP
I have three Saginaw PS pumps with three different diameter pulleys. I installed the largest on my 440-6 which seems correct, but would appreciate I confirmation of the correct pulley diameter.
Re: Need :PS Pump Pulley Dia. for 70 440-6 pk #72819
06/13/08 08:59 AM
06/13/08 08:59 AM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
it is tough to get a good measurment with the pump Nut installed, but mine looks to be right at 7".....
71 GTX 4sp Dana GY9 HD Road King
Re: Need :PS Pump Pulley Dia. for 70 440-6 pk [Re: AZ-Nick] #72820
06/13/08 08:35 PM
06/13/08 08:35 PM
Anonymous OP
Anonymous OP
My biggest one is just shy of 7", so I'll go with that. I has 2660 on the pulley, but not sure what that tells me.
Re: Need :PS Pump Pulley Dia. for 70 440-6 pk #72821
06/13/08 09:38 PM
06/13/08 09:38 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
thats a good choice because I remeasured mine again and it is just a hair under 7".....
Re: Need :PS Pump Pulley Dia. for 70 440-6 pk [Re: AZ-Nick] #72822
06/14/08 12:07 AM
06/14/08 12:07 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
It's probably a date code for the 266th day of 70?
Re: Need :PS Pump Pulley Dia. for 70 440-6 pk [Re: RoadRunnerJD] #72823
06/14/08 12:39 AM
06/14/08 12:39 AM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Its the date code - 266th day of '70 - for an early '71 Mopar.
Re: Need :PS Pump Pulley Dia. for 70 440-6 pk [Re: ebodyseast] #72824
06/14/08 08:38 AM
06/14/08 08:38 AM
Anonymous OP
Anonymous OP
My car is an early build 70, but it's the only Saginaw pulley I have of that diameter.
Thanks for checking and the info.!
