1970 Plymouth RR Conv Custom Project
#728216
06/19/10 05:48 PM
06/19/10 05:48 PM
Posts: 4,064 Boca Raton, Florida
jpilone
Boca Raton, Florida
So I am starting a new thread to sort of keep everything centralized on my moparts posting. I'm in the process of finally assembling my convertible after having it sit, painted, for over 3 years. I've been busting my hump getting things done, today I finally mated the engine and trans and have them resting on a cradle, ready to lower the car onto it (working at a dealership is great! hello lift-access!)
-Jarrod Pilone '70 Plymouth RR Convertible with amazing custom paint(Tribute/Recreation/Whateveryouwannacallit) My Project Thread
Re: My project thread (constantly updated)
[Re: jpilone]
#728217
06/19/10 05:51 PM
06/19/10 05:51 PM
jpilone
Boca Raton, Florida
And here's another angle. on Monday while on my breaktime at work, I'm going to install the power steering lines, headers, and carb. And the day after I'll get the valves adjusted, oil pump primed, and distributor properly set into position. Little details here and there to button up. I've got to get it in position so I can mark where to make the hole for the shifter (keisler 5 speed conversion kit)
[Re: jpilone]
#728218
06/21/10 12:45 PM
06/21/10 12:45 PM
jpilone
Boca Raton, Florida
For those who haven't seen it, here's a few shots of the paintwork.
As you can see, we went full custom with the paint. Everything we did started with "You know what would look cool?" The fire on the hood and the more cartoon-like bird was my idea, the fire dust trail was my painter's idea.
[Re: jpilone]
#728219
06/21/10 12:46 PM
06/21/10 12:46 PM
jpilone
Boca Raton, Florida
The bird on the fender is a copy of the bird on the GMP diecast box, but with a helmet added, all hand painted.
[Re: jpilone]
#728220
06/21/10 12:47 PM
06/21/10 12:47 PM
jpilone
Boca Raton, Florida
I let him have creative liberties with the trunk stripe.
[Re: jpilone]
#728221
06/21/10 05:09 PM
06/21/10 05:09 PM
Posts: 4,103 Horsham, Pa.
Finoke
Horsham, Pa.
WoW! I love the flames on the black. I can't believe some guys can do realistic flames. Really cool idea doing it as the dust trails too! How close are you to getting it up and running? Mine is in the paint shop now and I'm told I should be getting some color by August.
[Re: Finoke]
#728222
06/21/10 05:23 PM
06/21/10 05:23 PM
jpilone
Boca Raton, Florida
It's close to being able to run. Just about 10 minutes ago I lowered the car onto the engine/trans (well, real close anyways) so I can check fore/aft alignment and mark where I need to make the hole for the shifter. Tomorrow I'll take the seats out, and cut the hole, and then work on that little plate that keisler provides. I'm hoping to be able to fire it here in a few weeks. Running/driving, and only needing trim work by the end of the summer.
[Re: Finoke]
#728224
06/21/10 05:48 PM
06/21/10 05:48 PM
jpilone
Boca Raton, Florida
Here's when I dropped the K-frame over the other weekend.
[Re: jpilone]
#728225
06/21/10 05:51 PM
06/21/10 05:51 PM
jpilone
Boca Raton, Florida
My front brake setup (AR brackets for wilwood calipers, 11.75" rotors (late 70's B body application).
Re: 1970 Plymouth RR Conv Custom Project
[Re: jpilone]
#728228
06/21/10 10:46 PM
06/21/10 10:46 PM
Posts: 16,453 Canada
CrAzYMoPaRGuY
Canada
Haha! I knewwwww what it was before I opened the thread!!!!! I've seen it before and still like it just as much as the first time I saw it. Awesome.
CrAzYMoPaRGuY
[Re: satgtx]
#728233
06/29/10 02:54 PM
06/29/10 02:54 PM
jpilone
Boca Raton, Florida
I finally got it in!! Not very well (only two bolts in trans crossmember, but I'll get those in shortly)
[Re: jpilone]
#728234
06/29/10 02:55 PM
06/29/10 02:55 PM
jpilone
Boca Raton, Florida
I don't think I'll ever do another over/under again, what a pain it was to get it lined up and bolts in/secured!!
I have LOTS of work to do still, but the hard part is done.
[Re: jpilone]
#728235
06/30/10 07:10 AM
06/30/10 07:10 AM
jpilone
Boca Raton, Florida
So about 4:30 yesterday at work I started to work on the car to get the suspension back together.
Took me about 45 minutes, but it's all back together up front and now resting on all 4 wheels!
Today i've got to move the car to another bay, where it will remain until it's able to back out of the bay under it's own power!
