how did you hook up your aftermarket water temp?
#72750
06/13/08 12:07 AM
06/13/08 12:07 AM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
i bought a sport comp autometer 2 5/8 water temp the fitting already on the line i think is a 3/8 male flared...the fitting on my big block water pump housing is 1/2 npt i need a fitting to go into the water pump housing 1/2 npt on one side and 3/8 female flare on the other end with hole big enuff for the probe(for lack of better word)to pass into iv been to a few differnt places today that has fitting (like home de pot) with no luck how did you get around this?pic showing what you did? where did you get the fitting and size??
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: how did you hook up your aftermarket water temp?
[Re: codfish]
#72753
06/13/08 06:26 AM
06/13/08 06:26 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Advance auto here has them also.What suprised me is a friend bought cheap gauges and the fitting was included.Rocky
Chrysler Firepower
[Re: MoparforLife]
#72755
06/13/08 12:13 PM
06/13/08 12:13 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
well this is what i just did i bought a fitting (brass) that would work but the center hole was steped the probe would fit half way down till it met the steped part so i got a drill bit that was same size as the hole and drilled the other 1/4 inch way out now probe fits and sticks out the bottom like it should now i got to find a hole in the firewall big enuff for the fitting to pass through
[Re: toplescuda]
#72756
06/13/08 11:56 PM
06/13/08 11:56 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
On my Dart there is an oval sorta shaped body plug towards the bottom of the firewall, near where the steering column goes through.
codfish
[Re: toplescuda]
#72757
06/14/08 01:22 AM
06/14/08 01:22 AM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
Did you not receive anything in the instructions that talked about an adapter? AutoMeter offers many options for this. You can buy one that goes in the heater hose or the radiator hose that will allow accurate readings. This can be the easiest, and will let you use your factory set up and the after market also.
PM me if you want any info etc on autometer stuff, I'll give you the name of the person to talk to over there.
