Best Daily Driver 383 cam
#727183
06/18/10 12:13 AM
06/18/10 12:13 AM
Posts: 352 Arizona
69rrgrabber
Arizona
Any one have a favorite cam for a 383 daily driver? The car is a 69 Road Runner, with auto and 323 posi. It will be used for crusing cross country, stop lite to stop lite low end speed. Looking for good torque at low and mid RPM. This is what I have, stock 69 383, 9.5:1 CR, 3 angle valve job on stock heads, DP4 Eddie intake, 600 Holley, Headman Elite Headers, dual exhaust, x pipe, have stock 12 inch and 11 inch converter, auto, 323 posi. I already have a 440 car so max power isn't as important as max torque in this case. Thanks, Carl
"It takes a Mopar to catch a Mopar!"
1969 Charger R/T 440
1969 Road Runner 383
1970 Cuda 440
Re: Best Daily Driver 383 cam
[Re: TMBOOTS]
#727188
06/18/10 10:30 PM
06/18/10 10:30 PM
Posts: 352 Arizona
69rrgrabber
Arizona
Thanks for all the responses. I tried the online computer dyno to try to get an idea on how much torque vs horsepower the cams would give (ball park). All are in a good range,all will give, according to the program, 370 to 397 hp and 440 to 480 lbs torque, but the bigger 280 cam gives about 29 hp over the smaller 262 cam, and the smaller cam gives about 40 lbs of torque over the biggest. The Hughes cam and Voodoo cam are in between. What is better for a cruiser? gain 40 lbs torque or 27 hp? Maybe a better question is about how much torque does a 383 need to put out to push the Road Runner with ease? Thanks Carl
1970 Cuda 440
[Re: intragration]
#727192
06/19/10 04:16 PM
06/19/10 04:16 PM
Posts: 902 Seattle, WA
rss
Seattle, WA
It's a great cam, I just started driving my 440 'Cuda with a Mr. Six Pack. I wonder how it would run in a 383...
What are your thouhts on the Mr. 6 Pack cam? Is it really much different than the stock HP cam?
[Re: intragration]
#727194
06/19/10 06:12 PM
06/19/10 06:12 PM
rss
Seattle, WA
it seems to have a bit of an idle-thing going on, in a good way, more than I would think you'd see in a stock car.
Not sure I'm following you.
Most stuff I've read regarding the Mr. 6 Pack cam is that it has a super smooth idle. Some have described it as idling like a 6-cylinder or 318 stocker.
[Re: rss]
#727195
06/19/10 10:10 PM
06/19/10 10:10 PM
Posts: 352 Arizona
69rrgrabber
Arizona
Is there a web site to order a Mr Six Pack cam?
Thanks Carl
1970 Cuda 440
[Re: rss]
#727197
06/20/10 01:34 AM
06/20/10 01:34 AM
Posts: 242 midwest
intragration
midwest
I have stock quiet mufflers right now, and there's no mistaking my motor for a 318. It's not wild and crazy, but there's definitely something going on there. I'll know more once I get the new exhaust on. Here's his info, I don't represent him or have any affiliation with him, just a very satisfied customer. I just called him up and ordered with a credit card. He even spent time talking to my engine shop during the build process, giving recommendations and advice: Mr. Six Pack Bob Karakashian (248) 477-7776 mr6pk@hotmail.com
[Re: intragration]
#727198
06/20/10 02:22 AM
06/20/10 02:22 AM
rss
Seattle, WA
Thanks for the info. I'm going to give him a call to see if he thinks his cam will work well for my 383 build.
[Re: rss]
#727199
06/21/10 12:22 AM
06/21/10 12:22 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
Bob is a great guy. After talking with him on the phone I bought his cam two years ago for my street 383 build. It's not done yet so I can't say how well it runs in in a 383. He did tell me his cam is in many 383 engines. BTW, Bob does not grind his own cams, he has Ingle Cams grind it for him using his top secret specs.
Read more:
Bob Karakashian - Part 1
Bob Karakashian - Part 2
[Re: CompSyn]
#727200
06/21/10 12:38 AM
06/21/10 12:38 AM
rss
Seattle, WA
C'mon, get that thing buttoned up so you can let me know how she runs.
[Re: 69rrgrabber]
#727201
06/21/10 09:41 AM
06/21/10 09:41 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Thanks Carl
torque. where is the 27HP advantage? probably over 5000 RPM. how often do you buzz your motor up there? where is the 40 lb-ft advantage? probably in the 3000-3500 RPM range, where you're at a lot more. the midrange torque advantage also translates to a midrange HP advantage. I'd use a comp XE262 or voodoo 60302 if looking at an off the shelf grind.
[Re: 69rrgrabber]
#727202
06/23/10 09:56 PM
06/23/10 09:56 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
Thanks Carl
Hands down, gaining the 40 ftlbs of torque! You need it for "powering thru the gears", passing, or just plain hi-speed cruising (60+ mph or higher) on the highway!! But idle content is important too, so is quiet operation till you put foot in it!! I have to agree with some of the other members on the cam from Mr. Six Pack. Not that I am posting a plug for him, it just makes sense!! Especially with the 3.23's!!! All I can say is do more research on his camshafts.
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: HYPER8oSoNic]
#727205
06/25/10 12:32 AM
06/25/10 12:32 AM
Posts: 667 CA
66Dodge
super gas
super gas
CA
A guy would have to be on a marvelous, magical, delusion-filled trip to fantasyland to think there is a 40 lb-ft difference in peak torque between these cams. -dulcich
Simply put I answered the members post, with a non bias answer and WITHOUT criticism. 40 ft/lbs of torque is enough you can feel. Depending on the equipment used you can make that much or more over the stocker. So before you start your personal opinion on someone's elses project, think how you wouldn't want someone else "clowninig" your choices. Put yourself in their shoes for a change. Help, don't or IT MAY RETURN THE "FAVOR" BACK AT YOU!!
Dude! The guy you're bumping heads with (Steve Dulcich) writes technical articles for Mopar Muscle and other major car magazines. He's paid to do engine builds, dyno testing, and equipment/component performance test comparisons just to name a few. It's safe to say that his past articles and advice have helped others to achieve successful projects, solve tuning/performance problems, and saved us from throwing away good money. He has more real world knowledge/experience in his little pinky than you would ever have in your lifetime.
[Re: dulcich]
#727206
06/25/10 01:15 AM
06/25/10 01:15 AM
Posts: 352 Arizona
69rrgrabber
Arizona
Dulcich, I've read and enjoyed your tech articles a lot over the past 12 years+ I was very surprised to see that you would have any interest in such a humble search for a low horse power cammed, daily driver 383. Surprise turned to disbelief as I read your negative comment. The original cam I was looking at was the XE256H cam. I didn't mention that because I wanted to see what people had for advise for a cam. I guess you don't have any advise, just negative comments. All I have to go by are cam charts and a desk top dyno, and the desk top dyno by Comp Cams said 40 lbs torque between that cam and a bigger one suggested. I'd like to thank everyone who helped me out in choosing a cam. I really appreciate it. Carl
1970 Cuda 440
[Re: 69rrgrabber]
#727207
06/25/10 01:31 AM
06/25/10 01:31 AM
Posts: 667 CA
66Dodge
super gas
super gas
CA
Thanks, Carl
If you already have the stock RR cam in your 383 that should be adequate for what you want. That RR cam is perfect as is for what you want to do and then some. The rest of your combo sounds like a perfect fit. So why are you "dumbing down" to a cam with much more mild-manners ? Just don't lead foot what you have and you'll be fine. BTW, I don't get it. You have headers, x-pipe, DP4B, and you still want to dumb down to an XE256 ?! That's like installing a RV/towing cam. LOL
[Re: dulcich]
#727209
06/25/10 04:12 AM
06/25/10 04:12 AM
Posts: 667 CA
66Dodge
super gas
super gas
CA
The difference between the XE256 and XE268 is just 7ft.lbs. of torque and that 7ft.lbs. moved only 500rpms down. And 500rpms less is like easing off the gas pedal about a 1/4". Am I missing something here ? What is it about the RR cam that you don't like for cross-country cruising and low speed stop and go. That's primarily all part-throttle driving. Any cam can do that and you won't feel the difference unless you really stab the gas pedal. Maybe all you need is to swap the 3.23 gears for 2.94 . Also, removing an RR cam out of an RR ? Why not just buy a land barge C-body instead. LOL
[Re: CompSyn]
#727210
06/25/10 06:15 AM
06/25/10 06:15 AM
Posts: 836 lancaster, new york
macmic87
lancaster, new york
Read more:
i actually just finished installing the six pack cam in my road runner with 3:54 gears last week. my street car is a pleasure to drive now and tuning is a breeze (with a six bbl). higher vacuum, smoother idle and good torque down low is what you want for a street car.
[Re: dulcich]
#727212
06/25/10 11:20 AM
06/25/10 11:20 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I wasn't trying to bust anyone's chops with that reply. I think the engine "dyno" programs are generally misleading. The exception would be the most sophisticated and unsually expensive ones, and only when given very good and detailed data.
To generalize, cams will tend to move the torque peak rpm and change the shape of the torque coure, rather than add and subtract vast quantities of torque, unless something is really wrong. 40 lb ft just isn't realistically up for grabs here by going with a smaller cam.
Here's the peak torque results from a dyno test on a very basic small block Chevy, running all of the Comp XE cams, from the tiny XE250 to the huge XE294, run back to back with no other changes.
XE 250 475 at 3600 XE 256 472 at 3700 XE 262 476 at 4000 XE 268 479 at 41-4200 XE 274 477 at 4200 XE 284 477 at 4200 XE 294 480 at 4300
That is a pretty typical result. -dulcich
The peak torque numbers might be close, but the torque curves are going to be quite different. The small cam should have a fairly flat torque curve from 1,500 to peak torque than drop off fairly quickly. The large cam might be down as much as 100 ft/lbs @ 1,500 RPM compared to the small cam at the same RPM, and the torque curve will ramp up to peak torque, and fall off slower past peak torque.
My on the Mr six pack cam is that it might have advertised specs close to a stock HP cam, but ground with agressive 0.904" tappet lobe profiles. Would that be a stock "cheater" cam
[Re: 451Mopar]
#727213
06/25/10 08:49 PM
06/25/10 08:49 PM
dulcich
You are precisely right with what you are saying. -dulcich
[Re: 66Dodge]
#727214
06/25/10 08:56 PM
06/25/10 08:56 PM
HYPER8oSoNic
Desert Tracker
Yes, Steve has a very good reputation as a world renouned Mopar journalist. None that I dare to question. He has helped me quite a bit with his excellent tech articles, too!! There is no question about that, either!! No harm done. I simply voiced my opinion about the remark he made. I understand he gets "the brunt" sometimes in his replies to his articles, and as an automotive journalist, it shouldn't matter. Criticism is part of journalism. And as I had said before, I may not agree with you, but I WOULD NEVER DISRESPECT YOU. The idea of me bumping heads with Steve is what YOU say! Read my post you quoted carefully, it refers to the REMARKS, not Steves technical expertise! That's why I replied the way I DID! Steve, no harm done man. Just expressing myself on the negative comments NOT your tech buddy!
[Re: dulcich]
#727216
06/25/10 10:46 PM
06/25/10 10:46 PM
Posts: 667 CA
66Dodge
super gas
super gas
CA
[Re: 69rrgrabber]
#727219
06/26/10 09:59 AM
06/26/10 09:59 AM
451Mopar
Aurora, Colorado
This got me curious, so I plugged the comp XE262 and the comp 280 cams into my Dynomation5 simulator (both installed at 106 cl), and it shows a 23 ft/lb peak torque difference. Here are the numbers the sim came up with: Cam 262 280 280@100clRPM HP TQ HP TQ HP TQ 1000 75 391 68 359 72 378 1500 118 413 109 382 115 402 2000 161 422 148 387 155 408 2500 213 448 199 419 208 437 3000 260 455 243 425 252 442 3500 310 465* 293 440 308 462* 4000 343 451 337 442* 347 456 4500 359* 419 361* 421 368* 429 5000 350 368 359 377 365 383 5500 326 311 343 328 343 328 6000 286 251 311 272 303 266 The smaller cam really is a better fit for your combination. The larger cam is showing higher numbers for charge loss (reversion into the intake), this is one reason advancing the cam helps, the other is advancing the cam closes the intake sooner building more cylinder pressure. After messing with this for awhile, I realized that your engine and setup is really close to stock, so I just plugged in the stock HP cam specs of 268/284 0.450/0.458, 115 lsa, installed at 106: RPM HP TQ HPhr TQhr 1000 71 373 71 371 1500 114 399 115 403 2000 153 403 153 402 2500 207 434 207 436 3000 255 447 257 449 3500 306 459* 308 463* 4000 345 453 351 461 4500 367* 429 375* 437 5000 363 382 372 391 5500 341 325 348 332 6000 302 265 310 271 The second set of numbers is using the same stock 268/284 duration with 115 lsa, installed at 102 icl, but using the same (fast)lobe ramp rate as the XE cam, and 0.490/0.500" lift. If the Mr Six pack cam is simular, it might be the one to use?
[Re: dulcich]
#727221
06/26/10 01:54 PM
06/26/10 01:54 PM
Posts: 352 Arizona
69rrgrabber
Arizona
I was too quick to judge and get bent out of shape. I will have to take things with a grain of salt for now on! Thanks for writing back and clarifying. Well I'm going with the 262 cam, I think the torque curve will be best for my application. The Mr. Six Pack cam sounds great too. The specs are secret from what I hear, but if it is in the 260 range then I'll go for it to take advantage of the .904 lifter. Thanks again to everyone for their time and responses, I really appreciate it. Carl
1970 Cuda 440
[Re: macmic87]
#727224
06/26/10 05:58 PM
06/26/10 05:58 PM
451Mopar
Aurora, Colorado
the six pack cam i installed was recommended to be installed at 115 center line. this was according to mr sixpack based on my gear ratio and tire height.
Sorry for the confusion, I don't know the specs of the Mr six pack cam (they are not disclosed, but if you have a cam it can be measured/profiled.) I was speculating that they may be close to stock, but with more agressive lobes? Besides, I was just posting "computer simulation" results for comparison, and not having all the specific information avaliable, I had to make some assumptions on intake and exhaust port length, taper and volume. I used flow numbers from a decent flowing stock 906 head, and the 9.5:1 compression that was listed in the original post.
[Re: 451Mopar]
#727226
06/27/10 09:07 AM
06/27/10 09:07 AM
macmic87
lancaster, new york
i went round and round trying to see what the exact specs were for the cam and that was a big secret. but after talking with mr six pack and alot of six pack cam users and not hearing a single complaint. i took a leap of faith and installed it. now this was after going through 2 other cams that did not respond well to the six barrel setup. the big point mr sixpack made about his cam was that it was not based on the common chevy lobe design and based on the lobe designs chryslers put out back in the day. this was to take advantage of the lifter dia. so my personal experience went well. i have alot of vacuum, an extremely smooth idle, and great tunability (is that a word?). again this is my street car and that is what i wanted for cruising. if i wanted a 1/4 killer i would have gone in different direction. here is the sheet that cam with the cam that i received.
[Re: ademon]
#727227
06/27/10 10:42 AM
06/27/10 10:42 AM
Posts: 5,948 British Columbia
chrisf
British Columbia
the vodoo cam in my near stock 383 4 speed is great! way more bottom and mid than i expected its stats are: 220/226 @.050 with 475/494 lift on a 112 lsa installed a 107
i have that same cam in a 383 and am very happy. good power. vacuum and idle. i would buy another voodoo cam in a heartbeat after using this one.
[Re: chrisf]
#727228
06/27/10 11:08 AM
06/27/10 11:08 AM
Posts: 90 NL
Frederick
NL
Just finished a 383 also with the Lunati 60302 (262/268 220/226 @.050 0.475"/0.494") Happy so far, break-in went fine, idles at 800rpm. No ticking lifters like I have heard on the comp XE series. How much vacuum are you pulling ChrisF? I'm getting 15" and a cranking compression of 145psi, seems a bit low to me? 383 +030, 9.58:1 compression, cam installed 108
383B, 9.8:1, Lunati 60302(220/226@0.050 262/268Dur, 0.475"/0.494", Stealth heads, Performer manifold, QF SS-750-AN carb, 3.31Diff, A833 4-speed manual.
[Re: chrisf]
#727229
06/28/10 12:41 AM
06/28/10 12:41 AM
Posts: 352 Arizona
69rrgrabber
Arizona
Hey, on that Voodoo cam, did you have to do anything special to the heads for the extra lift? Are the stock rockers fine? Do you need the matched springs? Carl
1970 Cuda 440
[Re: 69rrgrabber]
#727231
06/28/10 05:21 AM
06/28/10 05:21 AM
Posts: 90 NL
Frederick
NL
Stock rockers here too. Stock springs won't work. Suggest you use the springs Lunati recommend or something similar. I'm using 26918 Comp Beehives and 440 source heads. Thanks for the details, Ademon. Must be my lower compression then and testing cold.
[Re: macmic87]
#727233
07/10/10 09:47 AM
07/10/10 09:47 AM
HYPER8oSoNic
Desert Tracker
Good Deal!! What size and type of carb you are running on your combo? (Vac sec or air door type- AVS/AFB) Might of missed it in your post. It's the amount of vacuum that interests me, for the carb I would go with. Can't go wrong with it!!
