Page 2 of 3 1 2 3
Re: Best Daily Driver 383 cam [Re: HYPER8oSoNic] #727203
06/23/10 11:03 PM
06/23/10 11:03 PM
dulcich Offline
dulcich  Offline
A guy would have to be on a marvelous, magical, delusion-filled trip to fantasyland to think there is a 40 lb-ft difference in peak torque between these cams.
-dulcich
Re: Best Daily Driver 383 cam [Re: dulcich] #727204
06/24/10 09:52 PM
06/24/10 09:52 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
-dulcich
Simply put I answered the members post, with a
non bias answer and WITHOUT criticism. 40 ft/lbs
of torque is enough you can feel. Depending on the equipment used you can make that much or more
over the stocker. So before you start your personal opinion on someone's elses project, think
how you wouldn't want someone else "clowninig" your choices. Put yourself in their shoes for a
change. Help, don't or IT MAY RETURN
THE "FAVOR" BACK AT YOU!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Best Daily Driver 383 cam [Re: HYPER8oSoNic] #727205
06/25/10 12:32 AM
06/25/10 12:32 AM
CA
66Dodge Offline
super gas
66Dodge  Offline
super gas
CA
-dulcich
Dude! The guy you're bumping heads with (Steve Dulcich) writes technical articles for Mopar Muscle and other major car magazines.
He's paid to do engine builds, dyno testing, and equipment/component performance test comparisons just to name a few.
It's safe to say that his past articles and advice have helped others to achieve successful projects, solve tuning/performance problems, and saved us from throwing away good money. He has more real world knowledge/experience in his little pinky than you would ever have in your lifetime.
Re: Best Daily Driver 383 cam [Re: dulcich] #727206
06/25/10 01:15 AM
06/25/10 01:15 AM
Arizona
69rrgrabber Offline OP
Arizona
Dulcich,
I've read and enjoyed your tech articles a lot over the past 12 years+ I was very surprised to see that you would have any interest in such a humble search for a low horse power cammed, daily driver 383. Surprise turned to disbelief as I read your negative comment.
The original cam I was looking at was the XE256H cam. I didn't mention that because I wanted to see what people had for advise for a cam. I guess you don't have any advise, just negative comments.
All I have to go by are cam charts and a desk top dyno, and the desk top dyno by Comp Cams said 40 lbs torque between that cam and a bigger one suggested.
I'd like to thank everyone who helped me out in choosing a cam. I really appreciate it.
Carl
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: Best Daily Driver 383 cam [Re: 69rrgrabber] #727207
06/25/10 01:31 AM
06/25/10 01:31 AM
CA
66Dodge Offline
super gas
66Dodge  Offline
super gas
CA
Any one have a favorite cam for a 383 daily driver? The car is a 69 Road Runner, with auto and 323 posi. It will be used for crusing cross country, stop lite to stop lite low end speed. Looking for good torque at low and mid RPM.
This is what I have, stock 69 383, 9.5:1 CR, 3 angle valve job on stock heads, DP4 Eddie intake, 600 Holley, Headman Elite Headers, dual exhaust, x pipe, have stock 12 inch and 11 inch converter, auto, 323 posi.
I already have a 440 car so max power isn't as important as max torque in this case.
Thanks,
Carl
If you already have the stock RR cam in your 383 that should be adequate for what you want. That RR cam is perfect as is for what you want to do and then some. The rest of your combo sounds like a perfect fit. So why are you "dumbing down" to a cam with much more mild-manners ? Just don't lead foot what you have and you'll be fine. BTW, I don't get it. You have headers, x-pipe, DP4B, and you still want to dumb down to an XE256 ?! That's like installing a RV/towing cam. LOL
Re: Best Daily Driver 383 cam [Re: 66Dodge] #727208
06/25/10 03:24 AM
06/25/10 03:24 AM
dulcich Offline
dulcich  Offline
I wasn't trying to bust anyone's chops with that reply. I think the engine "dyno" programs are generally misleading. The exception would be the most sophisticated and unsually expensive ones, and only when given very good and detailed data.
To generalize, cams will tend to move the torque peak rpm and change the shape of the torque coure, rather than add and subtract vast quantities of torque, unless something is really wrong. 40 lb ft just isn't realistically up for grabs here by going with a smaller cam.
Here's the peak torque results from a dyno test on a very basic small block Chevy, running all of the Comp XE cams, from the tiny XE250 to the huge XE294, run back to back with no other changes.
XE 250 475 at 3600
XE 256 472 at 3700
XE 262 476 at 4000
XE 268 479 at 41-4200
XE 274 477 at 4200
XE 284 477 at 4200
XE 294 480 at 4300
That is a pretty typical result.
-dulcich
Re: Best Daily Driver 383 cam [Re: dulcich] #727209
06/25/10 04:12 AM
06/25/10 04:12 AM
CA
66Dodge Offline
super gas
66Dodge  Offline
super gas
CA
The difference between the XE256 and XE268 is just 7ft.lbs. of torque and that 7ft.lbs. moved only 500rpms down.
And 500rpms less is like easing off the gas pedal about a 1/4". Am I missing something here ? What is it about the RR cam that you don't like for cross-country cruising and low speed stop and go. That's primarily all part-throttle driving. Any cam can do that and you won't feel the difference unless you really stab the gas pedal.
Maybe all you need is to swap the 3.23 gears for 2.94 .
Also, removing an RR cam out of an RR ? Why not just buy a land barge C-body instead. LOL
Re: Best Daily Driver 383 cam [Re: CompSyn] #727210
06/25/10 06:15 AM
06/25/10 06:15 AM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
I have stock quiet mufflers right now, and there's no mistaking my motor for a 318. It's not wild and crazy, but there's definitely something going on there. I'll know more once I get the new exhaust on.
Thanks for the info. I'm going to give him a call to see if he thinks his cam will work well for my 383 build.
Bob is a great guy. After talking with him on the phone I bought his cam two years ago for my street 383 build. It's not done yet so I can't say how well it runs in in a 383. He did tell me his cam is in many 383 engines. BTW, Bob does not grind his own cams, he has Ingle Cams grind it for him using his top secret specs.
Read more:
Bob Karakashian - Part 1
Bob Karakashian - Part 2
i actually just finished installing the six pack cam in my road runner with 3:54 gears last week. my street car is a pleasure to drive now and tuning is a breeze (with a six bbl). higher vacuum, smoother idle and good torque down low is what you want for a street car.
Re: Best Daily Driver 383 cam [Re: dulcich] #727211
06/25/10 10:44 AM
06/25/10 10:44 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Hmmmm. Comp Cams web site: I remember seeing a side by side comparison a few years ago of the XE262H and XE268H cams installed in a 350 chevy engine. That comparison showed the 262 making 5 more ponds of torque over the 268.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Best Daily Driver 383 cam [Re: dulcich] #727212
06/25/10 11:20 AM
06/25/10 11:20 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
XE 250 475 at 3600
XE 256 472 at 3700
XE 262 476 at 4000
XE 274 477 at 4200
XE 284 477 at 4200
XE 294 480 at 4300
-dulcich
The peak torque numbers might be close, but the torque curves are going to be quite different.
The small cam should have a fairly flat torque curve from 1,500 to peak torque than drop off fairly quickly. The large cam might be down as much as 100 ft/lbs @ 1,500 RPM compared to the small cam at the same RPM, and the torque curve will ramp up to peak torque, and fall off slower past peak torque.
My on the Mr six pack cam is that it might have advertised specs close to a stock HP cam, but ground with agressive 0.904" tappet lobe profiles. Would that be a stock "cheater" cam
Re: Best Daily Driver 383 cam [Re: 451Mopar] #727213
06/25/10 08:49 PM
06/25/10 08:49 PM
dulcich Offline
dulcich  Offline
XE 250 475 at 3600
XE 256 472 at 3700
XE 262 476 at 4000
XE 274 477 at 4200
XE 284 477 at 4200
XE 294 480 at 4300
-dulcich
You are precisely right with what you are saying.
-dulcich
Re: Best Daily Driver 383 cam [Re: 66Dodge] #727214
06/25/10 08:56 PM
06/25/10 08:56 PM
Desert Tracker
Desert Tracker
-dulcich
Yes, Steve has a very good reputation as a
world renouned Mopar journalist. None that I
dare to question. He has helped me quite a bit
with his excellent tech articles, too!! There is
no question about that, either!! No harm done. I
simply voiced my opinion about the remark he made.
I understand he gets "the brunt" sometimes in his
replies to his articles, and as an automotive
journalist, it shouldn't matter. Criticism is part
of journalism. And as I had said before, I may not
agree with you, but I WOULD NEVER DISRESPECT YOU.
The idea of me bumping heads with Steve is what
YOU say! Read my post you quoted carefully, it
refers to the REMARKS, not Steves technical expertise! That's why I replied the way I DID!
Steve, no harm done man. Just expressing myself on
the negative comments NOT your tech buddy!
Re: Best Daily Driver 383 cam [Re: HYPER8oSoNic] #727215
06/25/10 09:12 PM
06/25/10 09:12 PM
dulcich Offline
dulcich  Offline
I'm not upset at all, or anything like that. I was just hoping for a chance to use that "marvelous, magical, delusion-filled trip to fantasyland" line because I thought it was funny and would open up the post for some more discussion on the effects of cams, and some of the simulation software. It was not directed at anyone personally. I'm sorry if the words hurt feelings, it was not meant to be personal. I try not to be nasty to anyone unless it is feets, or especially rapidrobert.
-dulcich
Re: Best Daily Driver 383 cam [Re: dulcich] #727216
06/25/10 10:46 PM
06/25/10 10:46 PM
CA
66Dodge Offline
super gas
66Dodge  Offline
super gas
CA
Re: Best Daily Driver 383 cam [Re: dulcich] #727217
06/26/10 01:41 AM
06/26/10 01:41 AM
-dulcich
I agree, Steve has forgotten more info than I will ever have at my disposal.
Re: Best Daily Driver 383 cam [Re: dulcich] #727218
06/26/10 07:26 AM
06/26/10 07:26 AM
Desert Tracker
Desert Tracker
-dulcich
Re: Best Daily Driver 383 cam [Re: 69rrgrabber] #727219
06/26/10 09:59 AM
06/26/10 09:59 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
This got me curious, so I plugged the comp XE262 and the comp 280 cams into my Dynomation5 simulator (both installed at 106 cl), and it shows a 23 ft/lb peak torque difference. Here are the numbers the sim came up with:
Cam 262 280 280@100cl
RPM HP TQ HP TQ HP TQ
1000 75 391 68 359 72 378
1500 118 413 109 382 115 402
2000 161 422 148 387 155 408
2500 213 448 199 419 208 437
3000 260 455 243 425 252 442
3500 310 465* 293 440 308 462*
4000 343 451 337 442* 347 456
4500 359* 419 361* 421 368* 429
5000 350 368 359 377 365 383
5500 326 311 343 328 343 328
6000 286 251 311 272 303 266
The smaller cam really is a better fit for your combination. The larger cam is showing higher numbers for charge loss (reversion into the intake), this is one reason advancing the cam helps, the other is advancing the cam closes the intake sooner building more cylinder pressure.
After messing with this for awhile, I realized that your engine and setup is really close to stock, so I just plugged in the stock HP cam specs of 268/284 0.450/0.458, 115 lsa, installed at 106:
RPM HP TQ HPhr TQhr
1000 71 373 71 371
1500 114 399 115 403
2000 153 403 153 402
2500 207 434 207 436
3000 255 447 257 449
3500 306 459* 308 463*
4000 345 453 351 461
4500 367* 429 375* 437
5000 363 382 372 391
5500 341 325 348 332
6000 302 265 310 271
The second set of numbers is using the same stock 268/284 duration with 115 lsa, installed at 102 icl, but using the same (fast)lobe ramp rate as the XE cam, and 0.490/0.500" lift. If the Mr Six pack cam is simular, it might be the one to use?
Re: Best Daily Driver 383 cam [Re: 451Mopar] #727220
06/26/10 11:24 AM
06/26/10 11:24 AM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
the six pack cam i installed was recommended to be installed at 115 center line. this was according to mr sixpack based on my gear ratio and tire height.
Re: Best Daily Driver 383 cam [Re: dulcich] #727221
06/26/10 01:54 PM
06/26/10 01:54 PM
Arizona
Arizona
I was too quick to judge and get bent out of shape. I will have to take things with a grain of salt for now on! Thanks for writing back and clarifying.
Well I'm going with the 262 cam, I think the torque curve will be best for my application. The Mr. Six Pack cam sounds great too. The specs are secret from what I hear, but if it is in the 260 range then I'll go for it to take advantage of the .904 lifter.
Thanks again to everyone for their time and responses, I really appreciate it.
Carl
Re: Best Daily Driver 383 cam [Re: 69rrgrabber] #727222
06/26/10 03:32 PM
06/26/10 03:32 PM
CA
66Dodge Offline
super gas
66Dodge  Offline
super gas
CA
Assuming you still have the stock RR cam in it, what is it about it's current driveabiliy/manners that you don't like ?
Page 2 of 3 1 2 3
