Re: 360 magnum flexplate/balancer
[Re: swingers_rock]
#727053
06/18/10 12:55 AM
06/18/10 12:55 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
So if I bought those weights could I use a neutral balance flexplate then weld those weights on my converter to balance it out? I have a 9" PTC 3500 btw.
Heres what you want to do, scout the boneyards for a 360 magnum flexplate with the weights "ON" it, then you can run neutral balanced converters, look at the later blocks (1998-2002), B&M no longer makes the flexpate for the 904 too 360 magnum, just the 727 too 360 magnum, now thats not to say the 727 flexplate won't work .
[Re: truckinkid]
#727056
05/01/11 05:53 AM
05/01/11 05:53 AM
joedust451
super gas
super gas
Branson, Mo.
if you dont mind coulsd you please tell me how to balance this engine. where i can find the weights. I have a 2002 5.9 with a 74-904 tranny. need help bad !
Do you have the flexplate from the 2002 magnum, i'm sure they had weights on them in that year. If not, scout the junkyards for one from a 360 magnum that has the weights.
