360 magnum flexplate/balancer #727050
06/17/10 08:21 PM
06/17/10 08:21 PM
Colorado
swingers_rock Offline OP
super gas
super gas
Colorado
Hey all! I got a stock 360 magnum short block ready to be put together and was wondering about the balance of it. I know they are balanced different the a LA 360. I want to know if these parts would be a direct bolt on and require no messing around. tranny is a 904 and the torque converter is neutral balanced.
flexplate
balancer
Re: 360 magnum flexplate/balancer [Re: swingers_rock] #727051
06/17/10 10:05 PM
06/17/10 10:05 PM
Tyler, TX
LandShark Offline
LandShark  Offline
Tyler, TX
I don't know if you are interested in this as an option but I bought these weights and used the magnum flexplate with stock 904 converter. I am extremely pleased and spent under $50...
http://cgi.ebay.com/Mopar-Torqueflite-72...=item563ba80cbd
Re: 360 magnum flexplate/balancer [Re: LandShark] #727052
06/17/10 11:56 PM
06/17/10 11:56 PM
Colorado
super gas
super gas
Colorado
So if I bought those weights could I use a neutral balance flexplate then weld those weights on my converter to balance it out? I have a 9" PTC 3500 btw.
Re: 360 magnum flexplate/balancer [Re: swingers_rock] #727053
06/18/10 12:55 AM
06/18/10 12:55 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Heres what you want to do, scout the boneyards for a 360 magnum flexplate with the weights "ON" it, then you can run neutral balanced converters, look at the later blocks (1998-2002), B&M no longer makes the flexpate for the 904 too 360 magnum, just the 727 too 360 magnum, now thats not to say the 727 flexplate won't work .
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: 360 magnum flexplate/balancer [Re: joedust451] #727054
06/18/10 08:36 AM
06/18/10 08:36 AM
Bama
BigDawg72 Offline
BigDawg72  Offline
Bama
I bought one of the 904 to Magnum B&M units from CRT a couple of months ago. It wouldn't hurt to check and see if he still has some stock.
Re: 360 magnum flexplate/balancer [Re: LandShark] #727055
05/01/11 01:04 AM
05/01/11 01:04 AM
ARKANSAS
truckinkid Offline
truckinkid  Offline
ARKANSAS
if you dont mind coulsd you please tell me how to balance this engine. where i can find the weights. I have a 2002 5.9 with a 74-904 tranny. need help bad !
Re: 360 magnum flexplate/balancer [Re: truckinkid] #727056
05/01/11 05:53 AM
05/01/11 05:53 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Do you have the flexplate from the 2002 magnum, i'm sure they had weights on them in that year. If not, scout the junkyards for one from a 360 magnum that has the weights.
