Re: How to determine a real Six-Pack block?
[Re: Mick70RR]
#72731
06/13/08 03:18 PM
06/13/08 03:18 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
HPP was referenced back in the late 50's. Personally I could care less if it is stamped HP or HP2, does not mean a thing unless you match it up to a known six pack VIN. We have all seen C bodys with both stamps.
Ok, well, beats me, I don't know what the HPP meant in the 50's, never dug that far back. I completely agree on your statement about the VINs.
What does the arrow mean, the stamp that looks like a sideways letter A?. It's on my block too.
The "arrow" is just was it appears, a sideways "A", according to Galens White Books it means the engine has 20 er cylinder bores from the factory.
[Re: beepbeep]
#72732
06/13/08 03:27 PM
06/13/08 03:27 PM
Posts: 1,476 Oh
RacerGofKGB
Got The Big One
Got The Big One
Oh
[Re: ScottSmith_Harms]
#72733
06/13/08 03:37 PM
06/13/08 03:37 PM
Scott, I will guess you second pic is six pack too...what better way try to trick than show the same Is the S440 75 truck? (I have a 76 here that is T440) I have only known that you check the vin to be sure of 6 pack, does anyone know about warranty blocks? Just the internals? If you needed a warranty block for a 6 pack, was it an HP block that you got?
[Re: DPelletier]
#72735
06/13/08 04:24 PM
06/13/08 04:24 PM
We also need one of those for the later "thin wall casting" myth that's perpetuated time and time again!
[Re: aspenrt360]
#72738
06/13/08 06:42 PM
06/13/08 06:42 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Ok how about this one. While at the MATS I got into a little disagreement with Daryl Finch. He claims that all 440 HP2 motors in 70-71 came with the 6-pack balancer and the HP,s got the forged balancer. I said I've have several original HP motors with the 6-pack balancer. Another myth?
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
#72740
06/13/08 07:55 PM
06/13/08 07:55 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
You are right about the first one, it's an original 1970 440+6 block from a numbers matching 70 Cuda. However, your guess on the second one is not correct, it's a regular old 440HP block.
That is correct, and so it remains.
The third photo is a factory Service Replacement 440 Short Block ("S" = Service Replacement) if you blew a 440 under warranty in 1970 (ANY 440) this would have been what your car recieved as a replacement. There was no HP or anything else unique about them.
#72741
06/13/08 11:01 PM
06/13/08 11:01 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Not to hi-jack but what does the EHP mean on my 77 440, 7T440 EHP, was told it was out of a Florida Highway Patrol car, no proof but runs strong.
Careful, your character's showing!
[Re: mopar346]
#72743
06/15/08 12:17 PM
06/15/08 12:17 PM
Posts: 4,150 lewiston, ID
cornucopia
lewiston, ID
E means cast crank.
[Re: mopar346]
#72745
06/16/08 09:34 AM
06/16/08 09:34 AM
Posts: 74,942 U.S.S.A.
JohnRR
U.S.S.A.
E means cast crank.
Which it is, does HP still mean HP?? And what significance does that have in 77?
yes HP means high performance .
what significance
[Re: JohnRR]
#72746
06/16/08 10:15 AM
06/16/08 10:15 AM
"The third photo is a factory Service Replacement 440 Short Block ("S" = Service Replacement) if you blew a 440 under warranty in 1970 (ANY 440) this would have been what your car recieved as a replacement. There was no HP or anything else unique about them."
Now, from working @ a dealer (not in the 70's) I know that if ordering a warranty part, you ordered the parts specific to the car...eg. if it was a Eddie Bauer Jeep that needed a wheel warrantied, you looked up the Eddie Bauer wheel, I assume it would have been the same then.
So, if you look up the parts to warranty a 70 6 pack with a grenaded bottom end, you go hmmmn short block, 4 barrel or 3 2bbls? The tech says six pack so you order 3462619 as opposed to the 3462617 4 barrel job.
There is where my question lies about the internals on a warranty block. Did it get stamped "S" at the dealer as it was installed as a replacement, or did they need to go a special route to order a warranty engine (seems unlikely).
If your closest depot happened to have the block you ordered, you probably had it right away, were they stamped at the depot? (unlikely)
Or was there a list of warranty part #'s for engines and transmissions? Seems like a pain in the @$$ to me, they certainly would not have done it for trim or whatever, why engines?
[Re: moparmarks]
#72747
07/14/08 07:42 AM
07/14/08 07:42 AM
Posts: 3,533 Indiana
Fury Fan
Indiana
It's my understanding that all 70-71 hi-perf 440 engines came with the 'cast-crank-style' damper. I have one, don't know whether it is an HP or HP2. And FWIW, it's in a C-body.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
#72749
07/14/08 10:10 AM
07/14/08 10:10 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Getitdone (Evil Dead)
You are assuming too much, that's all. The various engines sold as service replacments were never stamped at the dealer (as any kind of regular protocall) it was done at the factory. As far as ordering part#'s etc. Warranty/Service replacments had a tag rivoted to the side of the block with an assembly number stamped into it, 440 long blocks, short blocks, etc. carried a different number respectively. To my knowledge there was never a six pack specific number, only a 440 HP that fit all replacement needs respective to the year application. So, in conclusion, as I said before, regardless of any internal differences, all replacement blocks were stamped the same.
