Hydraulic clutch kit? #72475
06/12/08 06:48 PM
06/12/08 06:48 PM
In a town not near you.
clownzilla Offline OP
Do y'all know who has the hydraulic clutch kits that are less expensive than the Keisler kit for $649.00?
Man, that's expensive.
The early bird gets the worm, and the second mouse always gets the cheese.
Re: Hydraulic clutch kit? [Re: clownzilla] #72476
06/12/08 07:00 PM
06/12/08 07:00 PM
Stuart, FL
Grassosgarage Offline
Stuart, FL
'70 Cuda 440/auto
'70 Duster 340/4sp project
'70 Satellite convert 318 survivor
Re: Hydraulic clutch kit? [Re: Grassosgarage] #72477
06/13/08 10:10 AM
06/13/08 10:10 AM
Re: Hydraulic clutch kit? [Re: clownzilla] #72478
06/13/08 02:20 PM
06/13/08 02:20 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
I am not going to get into a pissing match here but the Keisler kit is the only complete boltin kit available (if it is available). There are many components available to put a fabricated kit together but you will have to do some engineering. (Tomsecks) Mark Gerko used to have a kit but he has since went out of business for personal reasons. I have a hydraulic kit from him but there was a little fabrication work involved. It is a very simple set up that works great. Uses Tilton products which are superior in the racing industry. Good luck on your project. Here are a couple of pics of my set up.
Re: Hydraulic clutch kit? [Re: Cuda340] #72479
06/13/08 02:21 PM
06/13/08 02:21 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
2
Re: Hydraulic clutch kit? [Re: Cuda340] #72480
06/13/08 11:40 PM
06/13/08 11:40 PM
Thanks for the info.
No pissing match intended, just looking at options and trying to save some money if at all possible.
