Re: Monster electric cooling fan upgrade. long. w/photos.
[Re: feets]
#723578
06/25/10 07:05 PM
06/25/10 07:05 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Here's the motor itself with the windings.
Looking at the details inside the motors, it's definitely German. Everything is precise and well fitted. This is definitely NOT a cheap electric motor like I've seen in parts house fans.
[Re: feets]
#723579
06/25/10 07:44 PM
06/25/10 07:44 PM
feets
Senior Management
Senior Management
Irving, TX
I guess this means I now have an extra fan. If anybody needs a slightly used monster two speed fan motor with a 20-1/2" blade attached, I've got a spare. You will need to open it up and glue the cover on the electronics. It should still work but you're on your own when it comes to building a shroud for it. I suggest a VERY sturdy frame to hold the motor.
[Re: HealthServices]
#723581
06/26/10 01:23 AM
06/26/10 01:23 AM
feets
Senior Management
Senior Management
Irving, TX
I don't know which system it feeds. My shop foremen all said it was feedback from that 4th line. I'd lean more towards that over the ME.
Front SAM maybe?
[Re: gtx69]
#723584
06/27/10 02:47 PM
06/27/10 02:47 PM
gtx69
super gas
super gas
[Re: gtx69]
#723585
06/27/10 02:48 PM
06/27/10 02:48 PM
gtx69
super gas
super gas
[Re: gtx69]
#723586
06/27/10 02:49 PM
06/27/10 02:49 PM
gtx69
super gas
super gas
[Re: Pat_Whalen]
#723588
06/27/10 08:44 PM
06/27/10 08:44 PM
feets
Senior Management
Senior Management
Irving, TX
I never thought about the 9 volt battery. I might try that and see what happens.
Gtx, that fan will move a lot more air once it's off that bench. I'm still waiting on a friend to bring his anemometer over to measure the air velocity coming off the fan with the radiator in front of it.
[Re: gtx69]
#723590
06/27/10 09:50 PM
06/27/10 09:50 PM
feets
Senior Management
Senior Management
Irving, TX
Mine moves a lot of air. If the fan is running I can open the hood and watch a dollar bill flap in the breeze by the windshield. I can also feel it blowing air out from underneath the car.
They're beasts!
[Re: feets]
#723591
06/27/10 09:56 PM
06/27/10 09:56 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Does your scoop open up into the engine compartment?
If so I wonder if there is a flow of a air out of the scoop when the fan is on and the hood is closed.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
#723592
06/27/10 11:26 PM
06/27/10 11:26 PM
feets
Senior Management
Senior Management
Irving, TX
It is open but I haven't checked that yet. I doubt it. The intake plenum blocks the opening.
[Re: feets]
#723595
06/28/10 02:22 PM
06/28/10 02:22 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
Common the negatives of the 9v and your 12v car battery (as long as the fan controller is looking for a 0v reference), and you should then be able to use the positive feed of the 9v as the trigger to the fan. I'd assume you'd be able to hear the difference in speed, but a tach would be nice to place on the fan blade base and get a real appreciation for the difference, if there is any
[Re: Pat_Whalen]
#723596
06/28/10 04:32 PM
06/28/10 04:32 PM
feets
Senior Management
Senior Management
Irving, TX
The common ground is what I was thinking. As long as I don't cross the other terminal with anything else on the car I should be good.
I'm out of 9 volt batteries. I was looking for one on to use in my multimeter this weekend. Gotta get more.
[Re: feets]
#723597
06/28/10 05:44 PM
06/28/10 05:44 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
Yea. I'd hate to read a thread about you trying to charge a standard 9v battery with your 12v car battery... or worse- your alternator. That would probably end ugly.
