Re: Monster electric cooling fan upgrade. long. w/photos.
[Re: Performance Only]
#723678
07/15/10 11:40 PM
07/15/10 11:40 PM
Posts: 28,063 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Let us know how it works. I can tell you that my fan being wired directly runs at the same speed as the factory installation judging by the sound. I'm not about to stick my finger in there and count the whacks.
[Re: Andrewh]
#723681
07/16/10 07:05 AM
07/16/10 07:05 AM
Posts: 2,091 Delray beach, Florida
Performance Only
i think the total run time would be somewhere between 3 and 4 hours. it did exactly what the directions said it would do, it burned the IC card.
machine shop owner and engine builder
#723682
07/18/10 09:31 PM
07/18/10 09:31 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Just a heads up for anyone wanting a real nice fan controller... I've been building my Torana for a while, and used a Spal controller to run the fans on it Spal Fan Controller and just got it all dialed in today. Works awesome Has low and high temp limits for the fans along with an a/c input as well (which I used) so it kicks them up automatically when needed. It can also use a factory sending unit if you want too, or add thier own. I am running mine off the stock sending unit..
[Re: gtx69]
#723684
09/20/10 06:09 PM
09/20/10 06:09 PM
gtx69
super gas
super gas
[Re: gtx69]
#723687
09/20/10 06:42 PM
09/20/10 06:42 PM
gtx69
super gas
super gas
[Re: gtx69]
#723690
09/21/10 08:00 PM
09/21/10 08:00 PM
feets
Senior Management
Senior Management
Irving, TX
I didn't have any luck bypassing the box and jumping power to the motor. It would spin once or twice then shudder back and forth while trying to cook the wires. I never did cut the wires to eliminate the box on the old style motor I played with. Maybe eliminating feedback from the control box will help.
When the fan died, would it start again? How long did it run on 20 amps?
I see that your fan is an aftermarket unit also. I wonder if it's made by the same people as the one Performance Only used? Is there a manufacturer's name on the motor or controller?
[Re: gtx69]
#723691
09/21/10 09:01 PM
09/21/10 09:01 PM
gtx69
super gas
super gas
I'm still testing the older fan.I have it hooked up to a battery and the battery to a charger set on 20 amps to keep battery charged so far the fan has been running nonstop for 5 hours no problems yetNo smoke no nothing just runnin.Here are some pictures.
When i went to 40 amps it ran for about 1 hour than quit.Wouldn'nt start back up.Went back out today started right up.Cut the wires from controller box black and red wires to battery no trigger wire.Fan started up didn't run it had to leave.Tommorrow i will let it run and see what happens.It is aftermarket got it from LKQ the name on the fan is DEPO 340-55012-000 date codes are 3-11-2010 also another date on it Jan-23-2010.
[Re: gtx69]
#723693
09/23/10 12:32 PM
09/23/10 12:32 PM
feets
Senior Management
Senior Management
Irving, TX
It looks like the older style aftermarket fans won't handle the direct 12v signal. Apparently, a 40 amp feed is a little too much for it. I haven't tried the old style factory fans. I could set one up to run but my battery charger will only hold 20 amps. It would eventually discharge the battery.
The new style fans don't have any issues.
[Re: 2fast4yourBrain]
#723695
04/24/12 11:32 PM
04/24/12 11:32 PM
feets
Senior Management
Senior Management
Irving, TX
The newer fan is the one to get. It requires the controller found in the new products section. Running a direct 12 volt feed to it will kill the fan.
I have not worked with the older fan. They had stand alone controllers and are wired differently than the fan I used. If you take that path, you're on your own.
[Re: PwrWgn340]
#723697
04/26/12 04:15 PM
04/26/12 04:15 PM
feets
Senior Management
Senior Management
Irving, TX
It should handle that with no problems. These things move an insane amount of air.
I don't know the dimensions of your radiator so I can't say how it will fit. The fans with the metal heat sink MUST use hooziewhatsit's fan controller. Other fan controllers on the market will NOT work with these fans.
