Band Adjustment question with Tranzact Valve body. #722225
06/12/10 10:32 AM
06/12/10 10:32 AM
Newark, OH
Hunted Duck Offline OP
Newark, OH
Do you adjust the bands for this valve body the same as any other valve body. Or does it need to be different?
Re: Band Adjustment question with Tranzact Valve body. [Re: Hunted Duck] #722226
06/12/10 10:46 AM
06/12/10 10:46 AM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
from their website:
http://www.gotranzact.com/tranzact%20instructions%20pro%20brake.pdf
Intermediate band Adjustment; flex or hard
back, tighten to 75 inch lbs. then back off
1 3/4 turns on new band or 2 turns on used
band.
Rear band; tighten to 75 inch lbs. then back off 1 1/2 turns on new band or 1 3/4 turns on used
band.
Re: Band Adjustment question with Tranzact Valve body. [Re: dc426] #722227
06/12/10 05:04 PM
06/12/10 05:04 PM
Newark, OH
Newark, OH
Thanks DC
Re: Band Adjustment question with Tranzact Valve body. [Re: dc426] #722228
06/12/10 08:30 PM
06/12/10 08:30 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
are the adjustment's the same for a 904 with a triple wrap reverse band, those sound like 727 adjustment's.
Re: Band Adjustment question with Tranzact Valve body. [Re: dartman366] #722229
06/12/10 10:35 PM
06/12/10 10:35 PM
Locomotion Offline
Locomotion  Offline
Doesn't the kickdown lever ratio influence the adjustment specs?
Re: Band Adjustment question with Tranzact Valve body. [Re: Locomotion] #722230
06/13/10 12:25 PM
06/13/10 12:25 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
No kick down, transbrake VB.
Re: Band Adjustment question with Tranzact Valve body. [Re: dartman366] #722231
06/13/10 12:59 PM
06/13/10 12:59 PM
Locomotion Offline
Locomotion  Offline
The internal lever: 5.0, 4.2, 3.8, etc.?
OEM specs seem to call for different back-off numbers based on ratio. I've been using 4.2 and stuck close to the "race" torqueflite adjustments. There's no telling what ratio you'll find when rebuilding an OEM core.
