Re: Are Champion RJ12YC's junk ?
[Re: mopowergtx]
#71850
06/13/08 07:10 PM
06/13/08 07:10 PM
i wonder which has more ZDDP (zinc) content.. champions or autolites?
And everybody knows Budweiser in the bottle is the best beer out there.
the best beer in the world only when its brewed in canada eh...
for the REST of you as far as champions suck(ing), if your engine isn't up to par tune wise, yah.. champions are not very forgiving.
#71851
06/13/08 08:00 PM
06/13/08 08:00 PM
Posts: 3,075 Eastern Ohio
mopowergtx
Eastern Ohio
Ok well if we include our Canadian friends in this, "real" Lablat's Blue is mighty tasty too.
[Re: RobR]
#71857
06/14/08 03:57 PM
06/14/08 03:57 PM
Posts: 216 clearwater,fl
postbody65
clearwater,fl
hi everyone been runing the champions rj12yc which edelbrock recomends but they're getting a rust color on them my specs on my engine are 440 .55 over 11 1/2-1 bme aluminum rods .620 solid roller 6 barrel set up with orange box ignition msd coil and wires never had this color before any help thanks guys
[url=http://www.postbody65@yahoo.com
[Re: postbody65]
#71858
06/14/08 05:21 PM
06/14/08 05:21 PM
Posts: 8,165 Left Coast
BobR
Left Coast
I would have to see but what kind of fuel are you using? Any octane boosters? MMT-methylcyclopentadienyl manganese tricarbonyl(in some fuel and octane boosters) can cause a rust colored deposit. Is the motor running good? Any chance of coolant seepage into your combustion? Any oil consumption? -Bob
[Re: BobR]
#71859
06/14/08 05:51 PM
06/14/08 05:51 PM
After reading all of these posts I would like to add one overview. If you are fouling new plugs there is something wrong other than the plug brand. ....If you are fouling your plugs on a mechanically sound motor you are either using the wrong heat range or you have tune up problems. -Bob
i said that earlier in this STUPID thread. perhaps the masses will listen to you.
#71860
06/14/08 06:58 PM
06/14/08 06:58 PM
postbody65
clearwater,fl
no water in chambers no oil consumption have been using vp booster with sunoco 93 octane runs great no misses but have always wondered about the cut back plugs thanks
[Re: postbody65]
#71861
06/14/08 07:24 PM
06/14/08 07:24 PM
helps promote a more uniform flame travel. IE: more stable, thus minimizing the chance of detonation. thats the only thing proven to work. V-grooves~U-grooves~slit ground electrodes~etc are all marketing gimmics. Platnium~Uridium~Titanium~etc tip plugs DO NOT promote a better spark, but are super hard and VERY wear resistant. hence the "go 60k without changing them" statements. Also there 3,5,7 times more $$$ then conventional plugs. now, i buy my CHAMPION J12YC for $3/pair, and change em once every couple of years regaurdless of milage, and i also inspect them twice a year, just to make sure there are ZERO problems. If one plans on keeping there plugs in there small/big block MoPar for more then say 8000 miles, you gotta be
[Re: 500ciDuster]
#71865
06/15/08 01:09 AM
06/15/08 01:09 AM
Posts: 450 Texas
6packattk
Texas
Fuel,air,electrical,fuel in the 80`s is better than the water we run now,fuel in the sixties(lead) better than racing fuel now.Autolites in my big blocks since the 70`s,ran ngk`s only in my motorcycles,now will run in my bee,still correct heat range,gap,fuel and air will run for long time,oil fired or fuel deluted won`t,had to say something after reading this post this far......amazing but autolites run longer with oiling problem than champs but champs still make the best race plug OK good night
