Re: 440 Vacuum advance, hook up ported or constant vacuum?
[Re: topside]
#718010
06/07/10 12:07 AM
06/07/10 12:07 AM
Posts: 5,155 CT
GTX MATT
CT
I say manifold vacuum but alot of people will disagree with me. If you want it to idle better and you tune your mechanical advance correctly use manifold vacuum. Ported vacuum is basically doing the same thing that your mechanical advance does. Nothing at idle and more advance at WOT/high rpms.
[Re: NV69B7RR]
#718011
06/07/10 01:27 AM
06/07/10 01:27 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Ported is correct. Manifold ads timing when you don't need it. Vacuum advance is to give more advance at light cruise to improve economy. Ported vacuum accomplishes this, and it's how the factory dist is designed to work. IMHO especially on a stroker, you should be running a dist that has been set up to use the most initial timing you can get away with, and bring in the mechanical when you need it.
[Re: dave571]
#718012
06/07/10 07:16 AM
06/07/10 07:16 AM
Posts: 1,226 Cookeville
Chilort
Will Work For Mopars
Cookeville
[Re: GTX MATT]
#718013
06/07/10 07:28 AM
06/07/10 07:28 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Anyone who would try to get better idle this way is an idiot!
[Re: NV69B7RR]
#718016
06/07/10 07:34 PM
06/07/10 07:34 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
My advice....ignore all the advice and try it both ways, see which works best for your setup.
By "try it both ways" I don't mean just move the hose, tune it around both ways and see which drives the best.
[Re: Dodgem]
#718018
06/08/10 12:28 AM
06/08/10 12:28 AM
Posts: 6,545 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
You might want to "red" that book again. If you set your mechanical at 35 total, the vacuum advance only adds to it at part throttle ie 35*+15* vac = 50*. At WOT it will still be 35. FYI ALL cars with vacuum advance use manifold vacuum. The only difference is ported shuts off the vacuum when the throttle is closed so no advance at idle. Strictly an emission control deal.
Kevin
[Re: moparts]
#718022
06/08/10 08:42 AM
06/08/10 08:42 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
And now you're both wrong. The only difference between ported and manifold is ported shuts it off at idle. Crack the throttle and they are the same. Easy test, get 2 vacuum gauges and hook them up, 1 ported 1 manifold and you will be enlightened
Kevin
Thank You
On a pre emission car the vacuum was hooked up at the base of the carb,
The vacuum advance is on top of your normal timing settings, gives you that 50 plus degrees of timing at light throttle to help with gas mileage
All timing is set with the advanced unhooked
hence my quest why even hook it up? Isn't this a 512cid wedge? Set it for performance and have fun.
[Re: hooziewhatsit]
#718024
06/08/10 02:39 PM
06/08/10 02:39 PM
Mr.Yuck
Brookeville, Md
And why not hook it up? If tuned correctly you won't know it's there, except for the mileage increases.
doubt you'll see much. Not like it's going to easy to kep ur foot out of 512 cubic inches.. I couldn't anyway
[Re: Mr.Yuck]
#718025
06/08/10 03:30 PM
06/08/10 03:30 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
I just had my dizzy recurved again by Don at FBO. The reason I had it done again is because this time I NEEDED to add back the vacuum advance to get my 440 to run right with the stock cast iron manifold & correct 4640SA Carter AVS carb.
Don added the advance mech & curved it to use MANIFOLD vacuum to give me 34º all in by 3400 rpm at WOT. This eliminates the possibility of detonation at high RPM's due to overadvancing.
1MYTGTX
[Re: 1MYTGTX]
#718027
06/08/10 06:02 PM
06/08/10 06:02 PM
Posts: 10,178 Someplace you aren't
SomeCarGuy
That doesn't seem right at all there. 3400 RPM, vaccum advance to get 34 degrees, at WOT.
