Re: Need help identifying casting numbers on Dana 60
[Re: Texican]
#717549
06/06/10 01:04 PM
06/06/10 01:04 PM
Posts: 4,681 Florida
BDW
Specifications and Applications All Dana 60 housings are marked with a "Bill of Materials" number and a date code (Figure 2). BoM numbers are found on the back of the right axle tube, 2-3 inches outboard of the center section. All Dana 60 differentials are also marked with a date code. The 'font' for these stampings is a sans serif style and the characters are about 1/8" high. Particularly for the axle tubes, the stampings are faint, so it is important to clean the area well and to visualize them in good light. The BoM number is a 6-digit number with a one or two digit suffix separated by a dash: XXXXXX- X. Date codes are found on both housing and differential and are formatted MM DD Y. Date codes are found inboard of the BoM number on the housing, and on the side of the cylindrical part of the differential. The year code on housings is always one digit and on differentials can be two digits. Housing date codes are followed by a letter (A, B, or C) which may indicate the work shift or factory line. Some differential stampings also show this letter suffix. Zeros are not used in month and day codes. Wide variation in spacing of the components of the date code is seen, and it is not unheard of to see two date codes stamped into a housing, one above the other. These two date codes are usually within a few weeks of one another.
Bill of Materials Numbers: 68-69 B body 3.54 Powr-Lok 602957-1, -2, -3, -4 4.10 Powr-Lok 602957-5, -6 69.5-72 B body 3.54 Powr-Lok 603109-1, -2 4.10 Powr-Lok 603109-3, -5 4.56 Powr-Lok 603109-6, -7, -8 70-72 B body 3.54 Trac-Lok 603222-1, -2 4.10 Trac-Lok 603222-3 4.56 Trac-Lok 603222-4 75-77 B body 5.13 Powr-Lok 603347-2 5.38 Powr-Lok 603347-1 69-71 E body 3.54 Powr-Lok 603080-1, -2, -4 4.10 Powr-Lok 603080-3, -5 4.56 Powr-Lok 603080-6, -7 70-72 E body 3.54 Trac-Lok 603226-1, -2 4.10 Trac-Lok 603226-4 74 E body 5.38 Powr-Lok 603425-1 77-78 Retail 4.10 Trac-Lok 603831-1 Maint.
67-70 D200/W200 Std 602423 68.5-70 D200/W200 Std, Powr-Lok 602010 69.5-72 D200/W200 Std, Powr-Lok, Trac-Lok 603016 71.5-75 D200/W200 Std, Trac-Lok 603236 76 D200/W200 Std, Trac-Lok 603769 77 D200/W200 Std, Trac-Lok 603775 78 D200/W200 Std, Trac-Lok 603892 71-75 D200/W200HD Std, Trac-Lok 603237 76-78 D200/W200HD Std, Trac-Lok 603647 70-71 B300/M300 Std, Powr-Lok, Trac-Lok 603160 71.5-74 B300/M300 Std, Trac-Lok 603313 74.5-75 B300/M300 Std, Trac-Lok 603516 76 B300/M300 Std, Trac-Lok 603645 76.5 B300/M300 Std, Trac-Lok 603768 77-78 B300/M300 Std, Trac-Lok 603774 78 B300 Maxi Std 603832
Axle shaft dimensions vary in Dana 60 axles. Dimensions of semi- floating (passenger car type) axles shafts are shown below. Shaft lengths are measured from the outer flange face to the inboard end of the shaft. Note that the right axle shaft is always shorter than the left, so unlike the Chrysler 8 3/4" axle, Dana 60 axle shafts will not interchange side-to-side.
BoM Dia.-splines L shaft R shaft 602957 1-1/2"-23 29-21/32" 28-9/32" 603109 1-1/2"-35 29-21/32" 28-9/32" 603222 1-1/2"-35 31-5/64" 29-11/16" 603347 1-1/2"-35 28-7/16" 27-1/16" 603080 1-1/2"-35 30-7/16" 29-1/16" 603226 1-1/2"-35 30-7/16" 29-1/16" 603425 1-1/2"-35 24-7/16" 23-1/16" 603831 1-5/16"-30 32-5/8" 32-5/8"
Dana 60 Gear sets Standard Series P4529919 4.10:1 P4529920 4.56:1 P4529921 4.88:1 P4529922 5.13:1 P4529923 4.38:1 P4529924 5.57:1 P4529925 5.86:1 P4529926 6.17:1
Pro Series 9310 High Strength Material P4529927 4.10:1 P4529928 5.13:1 P4529929 5.38:1 P4529930 5.57:1 P4529931 5.86:1 P4529932 6.17:1 P4529933 6.50:1
Part Numbers
382S Differential bearing cup 387A Differential bearing cone HM88510 Drive pinion outer bearing cup HM88542 Drive pinion outer bearing cone HM803110 Drive pinion inner bearing cup HM803146 Drive pinion inner bearing cone 18888 Drive pinion seal 18891 Drive pinion seal (Differs in configuration of lip) P4529485 Powr-Lok Diff. Clutch kit (Flat Plates with composite) 2852523 Powr-Lok Diff. Clutch kit (plain steel Flat Plates) P3571032 Differential Bearing Adjustment Shim Package P3571030 Drive Pinion Front Bearing Shim Package P3571031 Drive Pinion Rear Bearing Shim Package P5249453 Shim Kit (Includes 030, 031, and 032 Packages) P4529488 Ring Gear Bolt Package RDS6095 Cover gasket (Felpro) A7 Axle bearing A7LK Axle seal and retainer kit, left side A7RK Axle seal and retainer kit, right side (discontinued as of March, 2001)
[Re: Texican]
#717551
06/06/10 04:11 PM
06/06/10 04:11 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
That's the build date November 3, 1969.
[Re: BDW]
#2739322
02/03/20 12:56 PM
02/03/20 12:56 PM
Posts: 2 Fjärdhundra
S68S
Fjärdhundra
Part Numbers
382S Differential bearing cup 387A Differential bearing cone HM88510 Drive pinion outer bearing cup HM88542 Drive pinion outer bearing cone HM803110 Drive pinion inner bearing cup HM803146 Drive pinion inner bearing cone 18888 Drive pinion seal 18891 Drive pinion seal (Differs in configuration of lip) P4529485 Powr-Lok Diff. Clutch kit (Flat Plates with composite) 2852523 Powr-Lok Diff. Clutch kit (plain steel Flat Plates) P3571032 Differential Bearing Adjustment Shim Package P3571030 Drive Pinion Front Bearing Shim Package P3571031 Drive Pinion Rear Bearing Shim Package P5249453 Shim Kit (Includes 030, 031, and 032 Packages) P4529488 Ring Gear Bolt Package RDS6095 Cover gasket (Felpro) A7 Axle bearing A7LK Axle seal and retainer kit, left side A7RK Axle seal and retainer kit, right side (discontinued as of March, 2001) So, what are the ´67 Dana 60 BOM numbers? ´67 B-body i.e. Thank you.
