Re: E Body 4 speed Reverse Light
[Re: cataclysm80]
#71424
06/12/08 07:54 AM
06/12/08 07:54 AM
Posts: 707 Tecumseh, Ontario, Canada
Moparnut
If you have the four speed reverse harness it should have a rubber gromet that fits in the hole you want to drill. Mic the gromet size and drill hole slightly undersize. This way you will have a good snug fit. Reason: I have found that sometimes the gromets on repo harnesses are not the same as original and do not fit in there snug so it does not keep falling out.
[Re: cataclysm80]
#71431
06/13/08 10:26 AM
06/13/08 10:26 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
cataclysm80, you have an e-mail. I will try to measure my AAR in a little bit and get back to you.
Careful, your character's showing!
[Re: cataclysm80]
#71433
06/13/08 11:19 AM
06/13/08 11:19 AM
mopar346
The hole in mine measures 3/4 in. I didn't have a caliper handy but with a 6 in ruler from the backside lined up on the inch mark the 3/4 mark was at the edge but not fully visible. Hope it helps!
