Page 4 of 4 1 2 3 4
Re: 440 source stealth heads: GOOD?? BAD?? [Re: CSK] #712649
02/11/12 03:32 PM
02/11/12 03:32 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
the stupid stealths flow the same as the old stealth heads out of the box oh super stealth 267 cfm @ .550
You read the ad and 440 source says 875 HP and up
with their stroker kit and their super stealth
heads. You only fool yourself into thinking
how easy it is. You buy a $500 head and you get
a $500 head. Everybody wants the most HP for the
least amount $$$. Super Stealth's 100-150 HP
over regular Stealth heads without a major head
mod like Victor heads over RPM's? REALLY??? !~!
Like I said, you buy a $500 head, you get a $500
head... nothing more nothing less.
Snap your neck, mega G-force launch, is all I want!
Re: 440 source stealth heads: GOOD?? BAD?? [Re: SG duster] #712650
02/11/12 03:32 PM
02/11/12 03:32 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
thats it they stop @ 550
Re: 440 source stealth heads: GOOD?? BAD?? [Re: RAMM] #712651
02/11/12 05:59 PM
02/11/12 05:59 PM
The Great White North
RAMM Offline
RAMM  Offline
As a matter of fact I have a 512 combo going together right now that will have some Stealth heads on it that flow 284-288 on our bench. It will have a hydro flat tappet cam 9.5 to 1 and I expect 550-570 hp @ 5300rpm. J.Rob
Just saw this post and the 512 wound up making a whopping 523 hp and 583 ft.lbs. Yeah--I thought that was terrible and it is, although I think the cam and low compression has a major role in that. At least the 65 year old dude that owns it thinks its awesome. I have built '452 headed 451's that exceeed that with not much work at all. IF you just have to have aluminum heads then go for it, if you want to go fast then talk to somebody that knows. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: 440 source stealth heads: GOOD?? BAD?? [Re: RAMM] #712652
02/13/12 06:46 PM
02/13/12 06:46 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
ok did a little reshaping on short side ,opened up the roof 320@.600 2.14 valve not bad at all will work on seats for low & mid lift flow & post my results & thats just a little work,will turn off my phone & close the shop doors & see what more i can get note to all these are SUPER STEALTH HEADS FROM 440 SOURCE FOR A STOCK LOOKING HEAD ITS DARN GOOD moral of the story is out of box not so great,just a little grinding & sandpaper roll work,dang good so far, more to come ck
Page 4 of 4 1 2 3 4
